That indeed was my thought at the beginning, but I came to same conclusion as you, that's why second pack would be turned on all the time, it would be build on same cells as the big one and would have same Ah.In theory, it can be done of course but here is the problem. Better to have both packs to be charged to identical voltage when throwing the switch. How feasible is that given the premise of your question which is an on/off switch presumably out on your ride? You want to use the small additional battery as a nitrous bottle to give you a burst of speed. Nice idea but the practice is a bit more complicated.
If you leave the house running on the big pack, the big pack will deplete a bit and not be voltage matched to the small pack when you switch it on. What happens then? There is current transference from small pack to big pack because they aren't at the same voltage. All cells with the same parallel amp-hr's want to be at the same voltage. Depending on what the voltage drop is, that won't bode well for cell life over time.
I personally wouldn't do it but of course your call and my thoughts.
Indeed you are correct about being nicer to the packs connnected in parallel because of additive capacity but of course this doesn't not serve the OP's objective of more speed. I am quite sure you know that and quite right, if both batteries are charged to the same voltage and the switch in thrown at the beginning of the ride, there should not be an issue. But, takes this discipline of course.Far better to decide before you begin the ride if you're going to ride with 2 paks ON and in parallel for the entire ride or start out on the small pack, deplete it, turn it off, turn on the big pack and deplete it. (or vice-versa) I have two paks and run them in parallel every time I ride. You're being nicer to you packs when running them in Parallel, both are sharing the load.
I believe you should be ok with that strategy if both batteries are charged to the same voltage. A far more common practice of course isn't a speed bump but a capacity increase by connecting batteries in parallel.That indeed was my thought at the beginning, but I came to same conclusion as you, that's why second pack would be turned on all the time, it would be build on same cells as the big one and would have same Ah.
Not really, from what I understand your idea is to switch to higher voltage battery. My idea orginalny was to boost main battery voltage by adding a battery in series.Just so I understand A to B and thanks for sharing your wisdom on this, therefore other than SoC of let's say the bigger battery after a few miles into the ride and throwing the switch to the fresh and higher voltage battery for a 'speed bump' is this perfectly fine with no downside??...because that is what the OP is asking. I am curious as well. Sounds as though other than the bigger battery depleting faster than the smaller battery with same number of parallel cells in each battery..just no. of series difference, there is no other concern, is this correct?
Thanks again.
Exactly. Everything is already able to work up to 20s. Can you point out, whether I missed anything in my last reply? ThxJust wanting to point out that both packs being charged to the same voltage, for fear of a rapid equalization between the two, is irrelevant if we’re talking about connecting these packs in SERIES to provide more voltage for a “speed boost.” Packs connected in series don’t equalize, they add voltage. Packs connected in parallel do equalize and need to have the same voltage when connected.
However, two batteries at different SOCs will finish their discharges at different times, so a main pack that’s half depleted when the “boost pack” is plugged in will hit LVC before the boost pack, if the two batteries have the same capacity (p-groups).
I agree that the simplest option is to run the two packs together all the time, or rather, just get one larger battery in the first place.
Make sure your controller and accessories (throttle, display) will tolerate the higher voltage lest you let out the magic smoke.
Or use a higher voltage battery/system with a controller that has a speed switch so you can electronically turn down your performance as desired.
Thanks again.
