Ykick
1 GW
I’ve outfitted several RC Lipo packs with BMS/PCM. The only thing that’s really been a problem for me are rouge balance circuits.
On several installations I’ve experienced balance channel transistors shorting (or turning ON when not needed) and draining down individual cells or groups.
Like many here I’ve mostly installed BetstechPower BMS but I recently had the same problem with a SignalLab type circuit too.
Luckily, haven’t suffered any cells pulling down below 2.8V since LVC has caught the issue but it has ruined a couple commuting trips.
Due to the minimal balance current these BMS provide (50-80mA), I find myself lifting the damn bleed resistors off the board and just avoid the auto-balance function.
In my mind it’s not reliable (3-4 BMS have now suffered this issue) and with the large capacity cell groups, even when it works properly the amount of balancing is simply not worth the trouble. Plus, you must significantly over-charge other cells to bring up low cells.
I wished there was a way/place to buy Li-ion, Lipoly BMS/PCM without balance function.
Anyway, word of warning mostly to those of us who’ve installed BMS on bike packs. Check those cells, if any keep slowly dropping measure across the bleed resistor to confirm if the transistor has shorted or inadvertently turned ON. PITA…
