davidg11
100 µW
Hi all,
New here. But I've been reading a lot, so I hope I don't sound completely clueless. Just partly!
I live in the USA. I weigh 185 lbs. I'll just converting a simple older Mongoose steel framed mtn bike. 26" tires. Range-wise I can't ever see biking more than 13 miles in one round trip excursion (downhill for half of the 13 miles or 6.5 miles). Most of my trips would be around 6 miles round trip (downhill for half of that or 3 miles). And I have a long 1.5 mile 4-5% grade incline in those round trips
that I'd like to get 25 mph uphill on the 4-5% grade 1-2 mile incline and then jumps up to about 8+% grade in the final 1/5 mile.
I won't be making a Frankenstein battery, so I think I will be buying a 48V 10ah ($348) or 48V 15ah ($485) LiFePO4 battery from most likely ping battery unless I hear of another reliable but cheaper battery LiFePO4 pack. Feel free to mention any other battery competitors! (or is there a link?)
I also have decided on a front hub DD motor.
Now the problem is, even after reading a lot, I have no clue what motor or control system I should use. I looked at ampedbikes.com and from what I gather, they make their motor packages for a 36V battery and not a 48 volt battery. Amped has a "500-750W" motor with 9 x 7 windings (zero clue what 9 x 7 means( or what 9C means) or any of these other motor terms I keep reading) and comes with all of the following for $346:
Microprocessor controlled brushless speed controller 22A 35A max (but I have no clue what these controller numbers mean)
Spare Grips.
Brakes with motor cutoff switch.
Thumb Throttle with Battery indicator lights.
I'm trying to also keep this entire system under $800US...but the larger battery does push this ampedbike system, if it is indeedr what I need, up to $830
Now I can do almost the same setup from Cohnismotor.com and the total is $766 but with them it is a 1000 watt motor and THEIR 48V 15ah LiFePO4 battery.
And Cohnismotor's controller is:
Voltage: 48V
Power: 1000W
Net Weight: 0.68kg
Max. Cut-off Current: 30A
Max. Cut-off Voltage: 55V
I guess I'm mostly trying to narrow down what overall system I need for my location and trying to understand the difference in motors and controllers for my situation. But price does matter.
I guess after that point, I can concentrate on suppliers.
Any help appreciated! Thanks! Great forum!
Spare Grips.
Voltage: 48V
Power: 1000W
Net Weight: 0.68kg
