Hello,
I use a hub motor (HT3525) with 45V lifepo4 battery pack, and I have a problem:
during downhill above 40..45 kph the back-emf is higher than the battery voltage, so the back-emf charges the battery with uncontrollable current through the controller's MOSFET freewheel diodes and the BMS. Unlike the regen braking, the current can be very high because it is not limited (only by the serial resistance of the motor) and I'm afraid it may damage the battery at high speed.
What is the usual solution for this?
(if I put a diode on the power supply line, then normal regen would not work and the DC bus voltage may increase and damage the controller at regen. )
(moderator edit: Since it is not a circuit schematic or really a request for one, your post has been moved out of "Upload Your Circuit Schematics & Requests Here..." and into it's own thread so people can see it and you can get the help you are after.)
