for those of us who are building chain drive bikes, the performance of cheapo flanged freewheels that adapt rear sprockets is very disappointing. just two weak pawls, lousy tolerances, and a lot of lash to take up when you hit the throttle.
i've devised a way to adapt a good quality bmx freewheel (in this case an Origin8 Hornet) to an 80T or other 4 hole #25 sprocket- without a lathe, or welding which would damage heat treatment. these engage in just 3.33 degrees of rotation with 9 pawls- only 3 of which are engaged at any one time- which is a 50% higher engagement than 2 pawls, plus the leaf springs are way stronger. too strong in fact, which adds drag and noise when coasting. it's fairly easy to weaken the springs by straightening them a bit with needlenose pliers to tailor the drag and noise. the tolerances are much better on a performance freewheel, and indeed they're a marvel of engineering given all they must do in very limited space.
the key is to buy a 16T freewheel because the teeth spacing aligns perfectly with 4 hole sprockets- every 90 degrees. the Hornet has a 55mm diameter sprocket body. go buy a bimetal 2-1/8" hole saw, and drill through a bit of 1/4" aluminum plate. hole saws always have a lot of runout, and mercifully in this case that produces a nominal 55mm hole plus about .003-.005", so this creates a backing plate to bolt to. the Razor brand et al 80T sprockets are 54mm ID, so some very careful filing with a big half round will bump that out to press on to the freewheel sprocket body. go slow and check your fit up when filing... my lathe is up north so i went all cave man.
i'm still deciding on final fastener selection. will report back...
