skinny
Hello
I am asking for help in deciding which controller would work best for me. I am building a mid drive Lightningrods Small Block with a 72V battery and a CA3 on a 2008 Epic Expert. Any help would be greatly appreciated. The basic difference other than the dual mode are the MOSFET's as I know nothing about these things.
I am looking at the Power VeloCity 12F 4kW eBike Sinewave/Silent Controller - Dual Android-iOS-Bluetooth Programmable 4kW :
Dual mode sensored or sensorless operation: If sensors are disconnected, the controller will still spin the motor, so you won't get stranded if hall sensors fail
Sinewave power modulation makes motor run very quietly and vibration free (in sensored mode)
A wide range of features programmable wirelessly from and Android or iOS/iPhone devices
Voltage operating range 36-100v
Battery currents up to 50A
Phase currents up to 130A
12 Genuine AOT290L low resistance (RDS) MOSFETs (best specs)
Finely adjustable regenerative brake force
Adjustable 3 speed switch
Cruise control
Configurable hard or soft start option
Larger fins on the aluminum heatsink box for better heat dissipation and performance
Adjustable magnetic flux weakening for higher speeds and efficiency
Tested top unloaded speed with flux weakening enabled: 130mph at 100v
Bluetooth/Android programming is now standard.
or the
Power Velocity 12F 4kW eBike Sinewave/Silent Controller Sinewave power modulation makes motor run very quietly and vibration free
12 Genuine IRFB4110 low resistance (RDS) MOSFETs
Cruise control
Thanx for your help and have a great day!
Cruise control
or the
Cruise control
