batteryGOLD
Hi there people, hope Ur having a nice Sunday
Soo do you think paralleling batteries is safe? at 50% cases yes, but other 50% cases may be unknown behavior/safety, it's a matter of probability/lucky that you get two batteries containing BMS with common charge/discharge port
50% of BMS worldwide are same charge/discharge port, and the other 50% are SEPARATE charge/discharge port.
So it's a matter of lucky when U combine parallel two or more batteries..
if BMS has separate charge/discharge ports, paralleling power lines will lead to non protected share transfer between batteries..
This happens to all parallels, even if batteries are same or different serial configuration.
Imagine you have one 16S battery parallel to other 16S, if BMS has separate ports this is a non protected parallel case.
If one battery debalances then will receive charge from the other battery. this may overcharge unbalanced cells at debalanced pack
Allways play SAFE and check BMS type before any kind of parallel !!
and MAKE SURE at the moment of parallel connection, batteries are at same voltage level or near. If those at different voltages level, it could lead to 100 or more Amperes current flow from one battery to other.. Also a matter of lucky depends how much is the voltage difference between batteries delta Volts at the connection moment
Fun thing: Some chinease batteries have BMS separate charge/discharge port and China people connect output to charge port
strange thing.. but It works! I've seen many times that invention at CityCoco scooters. charge port is able to supply 30A peak dont know how.. Those Chinese people are masters at quick solutions!
Is also possible to paralell Lithium Ion with LiFePO4 and LiPo and Pb acid and vice versa, as long apply the math rules common interval working zone & BMS have same charge/discharge port
