Best of contacting line lyen and get the lowdown from him it might take a little bit because he's probably doing a lot of other things.
The way I understand the programming to work you open it up on your computer and you select what you want the controller to do you do not get a chance to see what the controller set up you can only flash your new settings from how I understand it. Plus you had to order the controller with a programming plug and then buy the programming harness with button.
