MikeSSS
A friend got a geared hub kit from Luna. The front, geared hub is about the same size as my DD front Aotema hub, but is probably lighter. Both are brushless, the GH has sensors, the Aotema is sensorless. Old rigid mountain bikes, with road tires and spring seats, were used for both hub motors.
Controller size is smaller for the geared hub, GH, it does not have an on/off switch, but there is a power button on the "dashboard". The Aotema's larger controller does have an on/off switch but does not have a "dashboard". The GH is made for 48v, the Aotema is made for 36v but will run well on 48v too.
On the road, both using Luna Shark, 48v, 14Ah, GA cell batteries: both bikes had about the same acceleration and top speed. There was some gear whine from the GH and sometimes some harmonic noise from the DD. Neither was loud, not even close. But they are sort of noticeable if you sneak up and leach somebodies wheel.
Low speed use was very controllable for both bikes, cogging rumble on the Aotema at low speeds is more noticeable when using 48v as compared to 36v, above perhaps 10 mph cogging is not apparent. I did not notice cogging rumble from the GH. The GH freewheels when electric power is not used, the Aotema DD does not freewheel but the drag during no e-power pedaling is not too bad.
With a 36v SLA gel cell battery on the Aotema powered bike and with the Luna 48v Shark on the GH bike, the GH bike had better acceleration and top speed. This was expected, but was not as big a difference as anticipated.
No climbing was done with either bike. Pub visiting was done though and either bike will get you to the calamari in fine style.
Well that's it, GH vs DD turned out to be sort of "six of one and a half dozen of the other".
