geosped
- Joined
- Mar 18, 2015
- Messages
- 258
I need advice on my next off road mountain bike. Based on my previous experience see pics It worked but ultimately died after about 30 or so rides. It wasnt an ideal solution. I was using a BMC Rear hub at 50a LiPo pack about 10ah. It provided more than enough power to climb litterly anything I threw at it . On my watt meter it made over 1200w. I would not go open throttle for more than 5 seconds. The setup was a BMC v2 low torque rear hub motor with MyLin controller on a 12s LiPo pack at 10ah pack. My issues:
1) The problem with this solution is it felt very heavy in the rear.(this rear hub motor is heavy)
2) throttle was not smooth.
3) Only have throttle based twist grip. No assist.
4) felt jerky not smooth when starting out.
5) would over heat on a long assisted climb.
6) motor burned out after 30 rides.
Now I'm a heavy guy 250lbs that likes to go off road on real trails so tight single track in dedicated mountain bike trails in North Georgia. I dont do a lot of concrete riding but mostly off road. So low end torque is more important that speed.
I cant afford a "real" integrated off road mountain bike so I'll be looking at another DIY kit.
What is the best bang for the buck and what whould you guys recommend. I dont really need a large battery back. I will only be riding 10 miles at the most with several water breaks in between. So maybe 10 miles of offroad tracks. I dont like noisy units and hopefully there is a mid drive that is fairly light weight that can still haul my fat but.
What's the best, compact mid gear drive that would support a "Clysdale 250lbs) for about 10 miles on some good off road mountain biking trails? My thoughts were 750-1000w mid gear BAFANG BBSHD MID DRIVE EBIKE KIT and a 10ah? Are there better alternative options? Thought please and thanks in advance for your response.
