CoolRextreme
100 µW
Hello all! CoolRextreme here.
Ill start by introducing myself to yall!
I have been a stalker of the E-board build forums here for about four months, and built my first Electric Longboard about six months ago!
I live a town or two above Sacramento (California, USA) Quite flat, but the town is flanked by hills.
I love building stuff, and when I first heard of Electric Longboards, I was instantly hooked.
I bought a longboard for 20 bucks from a garage sale, renovated it. And learned to ride a Longboard within a month.
Somehow I never fell down during the learning process, so I guess that zombie unicorn is watching out for me
After that month of learning to longboard, and doing some (rather quick) research on E-boards, I ordered the parts for the cheapest E-board I could build (About $300)
To avoid repeating myself (Way to lazy to do that!) Ill just throw you the link to that build process.
http://www.instructables.com/id/DIY-Electric-Longboard/
As for quick reference stats to that board:
Weight: 13 lbs.
Clearance; Ground to electronics casing: 2 in.
Clearance; Ground to board: 4 in.
Top Speed: 19mph
Cruising speed: 16mph
Range: 5 miles
Power: 1510 Watts
Batteries: x2 3S 5000mAh
Wheel size: 90mm
That was the newbie's newbie build. And I aim to improve myself, drastically.
Don't get me wrong. The board worked great! And I had a blast (and STILL have not fallen off)
But a sport-less 18 year-old without a girlfriend needs SOMTHING to run off of :wink:
So, with some endless sphere lurking, and some other research. I have figured out a (Hopefully) much improved version.
I kinda jumped the gun and ordered the parts already, but I am still open to any comments or concerns you all have!
My new build goals:
45 mph ultra max speed on level ground with a payload of 180 lbs.
25 mph on grades with payload of 180 lbs.
20% grades or highway overpass.97mm Longboard Wheels. For even better bump-rolling
Custom board
Great ground clearance. For nasty speed bumps, curbs, or probable light off-roading
Adjustable motor mount brackets that can work on any configuration (front/back, left/right, loosen/tighten)
12S Dual motors. MUCH better power and hill climb ability. Less strain on an individual motor/belt.
Tail Carry. For carrying small belongings/charger.
Carrying handle. Easier carrying of the board.
Nice wide deck. Better steering leverage/control with tighter trucks
Custom battery/electronics housing. On TOP of board for better ground clearance. Waterproof.
Deck: Custom
Motors(2): Electric Skateboard Motor 6355 230KV 2650W
http://diyelectricskateboard.com/product/electric-skateboard-motor-6355-230kv-2650w/
ESCs(2): Alien 150A 3-12S ESC Sensored Opto
http://alienpowersystem.com/shop/esc/alien-150a-3-12s-esc-sensored-opto/
Batteries(4): Multistar High Capacity 6S 10000mAh Multi-Rotor Lipo Pack (Where on sale 50$ each!)
http://www.hobbyking.com/hobbyking/...0mAh_Multi_Rotor_Lipo_Pack_US_Warehouse_.html
Wheels: 97mm Wheels Longboard Flywheels
Trucks: Caliber II 10"/50 Degree Skateboard Trucks
Gearing: 16/32 (1:2)
Also, just for kicks, I got some LED Car-under-body lighting stuff off e-bay. Remote controlled with RGB LEDs and plenty of synchronized flashing options.
Charging Set-up:
Power Supply: 835 Watts 69 Amps AC - DC 12 Volt RC Power Supply
http://www.ebay.com/itm/RC-POWER-SU...DC-12V-cb-efuel-50-70a-60-20-30-/301361360478
Charger: Turnigy MEGA 1000W 8S 40A Lithium Polymer Balance Charger
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=56257
Parallel charging/balancing board: 1X 2~6S LiPo XT60-Plug Parallel Balanced Charging Plate
http://www.airyear.com/26s-lipo-xt6...9.html?zenid=bdb3e1e1440e12c2a9a84d752d40a1ef
Two 6S 10,000mAh batteries will be wired in series, which will be wired to an ESC, which will in turn be wired to a motor.
The ESCs are connected by the receiver with a Servo Y cable.
I also have a Turnigy twin-output UBEC wired between one set of batteries and their ESC/Motor.
One lead (5V) powers the receiver.
the other (12V) will power anything else I may want
I think that about wraps it up. Custom deck will be wide enough to afford me really good leverage with tight-ish trucks.
45mph is really just the 'show speed' And I will most likely (almost for-sure) not be going that fast. (Yet. :wink: )
We shall see.
But I am certainly excited about going over 20mph. Just gotta remember to slow down for school zones.
I am certainly honored to be among all the smart guys, and look forward to learning from you.
Please sensi, teach me thy ways!
Questions so far:
Will the charging set-up work? (battery XT90 connections will be clipped off and I will have XT60s soldered on)
Dose having two motors increase speed efficiency vs. having one motor? (one motor may provide 70% efficiency alone, but both motors helping each other out might
have 85% efficiency?)
And from my understanding: High voltage means less amps traveling through the ESC and Motor, therefore generating less excess heat.
I have ordered a watt meter so I can see in real time how many amps I am pulling off the batteries and through the ESCs
Weight: 13 lbs.
Top Speed: 19mph
Range: 5 miles
Power: 1510 Watts
Wheel size: 90mm
My new build goals:
Custom board
Deck: Custom
Charging Set-up:
We shall see.
Questions so far:
