Golyo
We have an old Sparta Pharos in the family, it is a clone of the Yamaha XPC26 by the looks of it. It has a 24V brushed controller that is meant to work with NiCd batteries. From that I am assuming that it is similar with the other such controllers, and it cuts off the batteries at 20V+-0.5V. Because of this, if I use a 6S Liion pack the only problem is that about 25% of the batteries total capacity will not be used, because they will be cut off at about 3.3V. Somewhere I've seen that the NiCd packs had a built in 30A fuse, so if I use NCR18650PF Panasonic batteries in a 4P6S pack I should have almost 10 Ah and be on the safe side considering drain (the batteries are rated for constant 10A).
Is there something I am missing?
Obviously I will need to use a different charger. But other than that?
