(SOLD) 3010wh, 288 cell battery pack with BMS and charger £250
warrah
Isle of Wight UK
For sale, an 66v (nominal) 18s16p 18650 3010wh pack with a 70a ANT programmable BMS and a 10a charger, all wired up. Has only been cycled a handful of times, but has sat on a workshop shelf for a few years so will have lost a bit off its calendar life.
Pack is made from LG INR18650 MG1 cells, arranged in 18s16p configuration. The 16p are divided into two 8p bricks which are then wired together, which is useful to know if you are trying to get these packs to fit into a certain space.
I can send it inside this funky modified toolbox case if you like, or I can remove it. I can also throw in a 1kw 240VAC inverter for free if you are interested.
£350, can ship to anywhere in UK for free. Anywhere else and shipping is extra.
Where abouts are you? And do you have any pictures of the battery packs or their dimensions?
Hi, sorry for the late reply. The packs are those pink things in the photo, they are wrapped in a 6mm layer of foam, each pack is 15cmx20cmx21cm with the foam on. If you need me to take it offand photo then I can.
Im on the Isle of Wight but often stay on the mainland.
Sold, but I've got another one up for sale, see the other post
