StooopidMonkey
100 µW
MY RIDE:
Surron LBX 2020 - Like stock except for battery which is EBMX 60v63ah - removed all sensors not needed - installed electric throttle
PROBLEM:
Throttle cuts off when riding - either a shortage or pinched cable - if I move wire harness around it will work until I hit a pothole or something. I shoved all the wires back inside as I was having difficulties fitting everything in.
My display for speed turns off when I move it's wire around (needs replacing). Is this a possible reason for throttle cutting off?
I bought a multimeter but do not know how to use it nor do I know what each connection is supposed to read as or what to be looking out for.
ADDITIONAL PROBLEM:
As I was moving wires around with bike powered on I lost power and now have a problem with the battery working. Before I could push button to see battery percentage at any time and now it does nothing when pushed.
Also,
Is a Surron considered a bicycle or motorcycle?
- bike shops tell me its a motorcycle and refuse to look at it
-motorcycle shops tell me its a bicycle and refuse to look at it
PROBLEM:
ADDITIONAL PROBLEM:
Also,
