FortAwesomeIII
100 µW
- Joined
- Oct 25, 2012
- Messages
- 7
Hello, I have a 2012 Zero xu that I have immensely enjoyed for the past year or so and made a few light mods on. It has a little over 1000mi on it.
Lately, I have been reading a lot on electric planes powered by all sorts of motor/battery combos. They all interest me, and I have always had an interest in flying(never done it as a pilot, though). However, even getting started at the lowest cost possible building or converting an electric ultralight appears to be easily well over a $10k endeavor. That is prohibitive at my current budget.
Since most of that cost is in the power train, my thoughts on the matter are to figure out a way to remove the motor, battery, and critical components of my Zero Xu in order to use in an ultralight or plane. Ideally, one could be purchased that is structurally in good shape but with significant motor troubles on the cheap(~$2000-3000?). I wonder if the Zero motor/batt combo could power a plane/ultralight? It seems to me that it could, though I am not familiar with the rpm range of the motor and if the prop would be directly run at motor rpm or more or less on a pulley/belt system. Assuming this would work, I'd like to swap these components out for the plane's motor/fuel tank and give it a try. It would be worth it to me if this could work straight up as a semi permanent power plant to get the chance to fly, but I wonder if it would be possible to use the "guts" of my bike as a modular power plant for a variety of different applications? As it is, I am estimating that to remove and replace the items I am speaking of would take at least hours. Having an electric plane would be a dream come true, but it would be even better if I could still swap the motor and other components back into the bike just as easy as it is to remove and replace battery.
I would like to explore the possibility of swapping in the battery, motor, plus controllers, etc. in my waverunner, sailboat, possible flying machine, and maybe more. Does this sound absurd or am I on to something? Anyone ever thought similar ideas?
Thanks for reading!
John
Thanks for reading!
John
