I envision creating paralleled series, with each series being 2.5 of the above packs (5 packs total). That would suggest each series provides 81Vmax/75Vnom/45Vmin. While these max and nom values are acceptable, the min is not. Furthermore, upon looking closely at the discharge curve for these LTO cells, the Vmax is brief, lasting 2.7 to 2.5 over <5% initial capacity. The following 2.5 to 1.5 drop occurs over the remaining 90-95% of capacity. The lower end of that capacity curve concerns me, as it cumulatively drops below the controllers 72Vnom rating around 50-60% discharged (assuming 30S 2.4V cells).
Some thoughts I've had about this endeavor:
- Should I consider a Vmin threshold closer to my controllers rating, then somehow regulate the Vmax of the battery? E.g. With 3 full packs in series, the system would provide 97.2Vmax/90Vnom/54Vmin.
- What sort of BMS is optimal for such a design? With these modular 5 or 6 packs, each consisting of 12S cells, do I get (and do they even make) a 30S or 36S BMS? If so, would I use Y-splits to bridge each packs parallel cells?
- LTO is ideal for this application (safest, temperature robust, and longevity), but perhaps the above mentioned complications indicate an alternative chemistry is better suited (LiFePO4)?
