thinking of buying a used Leaf battery pack
Ive seen the discharge curves of the batteries before and they reminded me of the curves of the 30Q or 40T
and wondered if they could be "desulfated"
it looks severely out of balance to me
i googled nissan leaf battery fires and theres the odd fire but they seem to be a pretty safe battery while in the cars but what about them being used in second life situations?
how safe are used Nissan Leaf batteries
30Q test viewtopic.php?f=14&t=108547
40T test viewtopic.php?f=14&t=106550
Sony VTC6 viewtopic.php?f=14&t=108661
Desulfate 30Q, 40T, VTC6, P42a viewtopic.php?f=14&t=109601
Battery magnets viewtopic.php?f=14&t=106190&hilit=magne ... 5#p1563730
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Re: how safe are used Nissan Leaf batteries
They don't contain sulfur, so no. They don't work like lead-acid batteries.
If you are referring to the general process of recovering capacity, then no, that doesn't generally apply to lithium batteries. As they age or are damaged, they lose capacity permanently.
There may be special specific situations in which it is possible, but in general, no.
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
the whole thing weighs 650 pounds
trying to figure out how to get it home
bit of a write up on them
https://www.qnovo.com/blogs/inside-the- ... issan-leaf
could split it up into 4 or 5-72v packs for the boat
40 amps continuous from the boat from 4 packs is like 1/4 C
did some searching on the gen1 packs and a person mentioned you need to fully charge and discharge these batteries twice if they have been sitting for over 6 months, kinda like how i "desulfate" lithium
https://diysolarforum.com/threads/secon ... ost-172142
- DogDipstick 1 MW
How safe are they?
Watch this.
Watch this.
84v of Ironhorse XC.. by Chevy You call .. that.. a "glitch:" ? (...No Mom. The formula is Kaw > 1(Hr) = Impounded. The math checks out. I'll be fine. ).. Broke20Horsies! 17,830w !! 1 (pound / second) Hp = 338.24 M^2 Kg^2 / Sec^4 ) isn't 13" x 27".. Oh nvrmnd 4+25% = 5 ; 5-20% = 4... 5(1-20%) = 4.. so, to correct the incorrect reading, of 4 ... 4(1+25%) = 5 Fabricator @BSECo. God. Damn. Slugs.
thanks corn dog
i feel the need to pay you back with some comedy
https://www.youtube.com/watch?v=K2xHK_66xWw
