I’m not sure that value is correct. I think the stock firmware does what most of the OSF’s do if you haven’t chosen to do a software calibration, which is to read the unweighted value at startup and use that as a zero. Because of safety there has to be a bit of leeway, it might use 10-15 under the read value on startup. If you’ve only got a total range of 60 then there is not much to work with if the multiplier of that value is hard coded. I’d suggest MBrusa’s firmware… can fix the problem either with software calibration, which basically remaps that range of values to a larger one, or just by adjusting the actual power multiplier for each level. If the hardware range is small then obviously there is a low resolution. I’ve found mine ok with a range of about 85 from resting to standing on the pedals which has been satisfactory.Inertiatic wrote: ↑Feb 13 2023 5:00amDoing a bit more digging it seems that the lowest figure should be ~300 at 0 input.
If that's correct, then mine appears to be reading very low...which also makes sense why it would be underpowered.
I've ordered the bits to make up a data link and been playing with the OSF software...
There is also the question of linearity of the sensor signal compared to input torque. Mbrusa firmware has some further calibration that can be done to try and more straight-line the curve, so to speak.
