Who makes this torque arm???
Floont   1 kW
Post by Floont » Apr 25 2013 1:21pm
It's funny how you can order stuff and keep every email and piece of paper, but cannot find what you're looking for when the time comes to get another.
So I am asking the general population... Who makes this torque arm???
Build 2: (present build): Rear x5304 on full suspension Mongoose, 127v 30s3p 10aH Turnigy Lipo, Lyen 24FET 100amp controller, CA2.2, 26" Hookworm front, 26" Crazy Bob rear, 203mm disc brakes, Airzound horn, twin Blaze 2 watt front lights - BURNED
All my posts on this site are licensed under the Creative Commons Attribution-Noncommercial-No Derivative Works 3.0 License
bowlofsalad   1 MW
Re: Who makes this torque arm???
Post by bowlofsalad » Apr 25 2013 1:47pm
I think sabongi has it right, I just got one of those in the mail, looks like it to me.
Floont   1 kW
Post by Floont » Apr 25 2013 3:12pm
THANKS!!!
That's the confirmation I was looking for.
dogman dan   100 GW
Post by dogman dan » Apr 25 2013 5:27pm
Or they've copied it already. Buy yours from Grin Cycles of course.
mark5   100 kW
Post by mark5 » Apr 25 2013 6:35pm
dogman wrote:Or they've copied it already. Buy yours from Grin Cycles of course.
Methtek has them too if Floont might prefer to pay US vs Canada postage.
bowlofsalad   1 MW
Post by bowlofsalad » Apr 26 2013 10:59am
I wish I had known that a few days ago.
mark5   100 kW
Post by mark5 » Apr 26 2013 2:08pm
Don't feel bad--I'm the one who once paid $15 Canada Post postage for a $4 C-washer.
Plus that torque arm costs $12 less now than when I bought mine.
docnjoj   100 GW
Post by docnjoj » Apr 26 2013 3:22pm
I would actually consider getting that TIG welded instead of the nut and bolt. Probably $50 extra around here but......... if it spins you need to rewire. I think except for custom by John in CR or Farfle that one by Justin is as good as a rear torque arm gets. Just dont like the bolt! Why won't the motor companies copy Heinzmann?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
Floont   1 kW
Post by Floont » Apr 27 2013 9:44am
I use two. One for each side of the bike. So as long as I inspect the bike before each ride, I should be OK... even with a bolt.
The problem right now is I only have one installed at present, so I have to limit jackrabbit starts and high torque situations until my new torque arm comes in.
bowlofsalad   1 MW
Post by bowlofsalad » Apr 27 2013 10:13am
Do you use nord lock washers? It's starting to seem apparent to me that without nord lock washers, the only viable option would involve either epoxy or welding.
Does your torque arm obstruct any part of the rear derailleur? Mine does and I am not sure what to do to get around it. Right now I am considering either creating the gap I need with nord lock washers, or using an angle grinder to get the small amount of metal out of the way on either the derailleur or the torque arm.
RLD70   100 W
Post by RLD70 » Apr 27 2013 10:41am
+1 Ill second that, buy it from Grin Cycles.
Floont   1 kW
Post by Floont » Apr 27 2013 1:39pm
bowlofsalad wrote:Do you use nord lock washers? It's starting to seem apparent to me that without nord lock washers, the only viable option would involve either epoxy or welding.
I no longer use a derailleur, I use a chain tensioner... which can be found online anywhere. The chain tensioner doesn't interfere with the torque arm.
Regarding washers, I don't use them, I use "nylock" nuts, which grab the bolt tightly to keep it from loosening (unless you've used them too many times).
bowlofsalad   1 MW
Post by bowlofsalad » Apr 27 2013 2:02pm
http://www.youtube.com/watch?feature=pl ... gwmuZuJ02I#!
I don't know if you've seen this video, but they perform vibration tests with various kinds of locking options such as the nylon nut. It's a pretty compelling video. I'd still suggest checking the tightness of the nut, even if your torque arm was glued to your bike.
I am guessing some people give up some or most of their ability to shift gears as they feel it is pretty close to unecessary. But I see a well kept bicycle apart from the electric components as a great safety net. Even if the battery is dead, even if the controller goes wrong or who knows, you still have a backup option. It's a huge selling point for myself, never being stranded. I've seen people walking with their red container for a gallon of gasoline. I've even given them a ride or two. No such thing with an ebike short of something wrong with the bike itself.
dogman dan   100 GW
Post by dogman dan » Apr 28 2013 6:22am
If you need it, don't hesitate to grind a small amount of metal away to properly fit the torque arm. But don't grind away enough to weaken it.
It's not so obvious at first, but bear in mind that the use of more than one clamp on the other end of the torque arm goes a long way too prevent the design from relying entirely on the tightness of the nut. If the piece on the stay cannot pry away, the joint at the bolt can't rotate.
The one failure of this type of arm I've seen so far was the axle rotating inside the main plate. The axle was not a tight fit in that case, and got moving enough to wallow out the plate.
Floont   1 kW
Post by Floont » Apr 28 2013 2:00pm
bowlofsalad wrote: Do you use nord lock washers?...
Where can you purchase nord lock washers???
I watched the video and I'm convinced they are superior in vibration situations.
FA
Boeckstyns   100 mW
Post by Boeckstyns » Apr 29 2013 1:46am
