Need 36v batt. Recommended vendors please.
torker   1 MW
Post by torker » Nov 27 2022 1:19pm
I have been searching for a small 36 v batt for my iride bike. It is only rated 250w It shouldn't need a big battery.
Any reviews for BTRPower? Or other vendors you have used.
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Trance 9C 6*10 36 v x 20 amps
Specialized FSR 9C 6*10 48 v x 30 amps
999zip999   100 GW
Re: Need 36v batt. Recommended vendors please.
Post by 999zip999 » Nov 28 2022 1:54pm
169.00 is cheap and making a profit ? What cells are they using this includes a BMS and charger in the price. That's a lot of components. Maybe they're getting some of their money back in shipping like BMS battery used to do ?
How much to ship ? Ask him what sells they use most time they'll just tell you Tesla like sells. I hate when that's the answer.
torker   1 MW
Post by torker » Nov 28 2022 8:07pm
I liked the warranty and the US warehouse. But, no idea of what cells or bms used.
Em3ev is great. I have 2 of their batteries. About double the price but worth it..
I am trying to get this old bike going on the cheap. Not easy or recommended way to go.
Really seeing if someone has used Btrbattery..
E-HP   10 GW
Post by E-HP » Nov 28 2022 8:19pm
Given the configuration (10S4P), ignoring the cost of the BMS, assembly, and profit, that would come to $4.22 per 2500mAh cell. I would guess not brand cells, given the conservative imputed price, so if you're fine with generic Chinese cells, and running them within their capabilities, then may be worth taking a chance on them.
torker   1 MW
Post by torker » Nov 28 2022 10:27pm
It is only 250 w so it won't take much to power. My other option is to get another 12v lifepo4 . I have 2 now. Then buy a bms and wire it. Which I have never done.🙄 I can get another for 45 dollars, maybe less. They are used and 20 ah.
ngant17   1 W
1 W
Post by ngant17 » Dec 27 2022 1:03am
A friend of mine uses a 36v Bafang with rear hub. I recently suggested Ryobi lawnmower batteries as a possible replacement, which are 40v, 6aH. I've used Ryobi electric lawnmowers and their 40v, 6 aH batteries hold up very well. Not sure who's making Ryobi battery adapters with a 3D printer yet.
The higher 40v should not set off any over-voltage errors on a 36v Bafang. For example, my Bafang BBS02 is a 48v motor and runs on 60v with no problem, error code 07H will shut down motor at approx 61.5v. I have over 2000 miles on engine to date. Bike still runs like new.
Exitor Magna mountain bike, dual suspension
Bafang BBS02 motor 48V / 750W
L̶u̶n̶a̶ C̶y̶c̶l̶e̶ "M̶i̶g̶h̶t̶y̶ M̶i̶n̶i̶" 3̶0̶T̶ (chainring bolts dropping out, temporarily down for locktite app)
S̶R̶A̶M̶ 1̶/2̶" x̶ 1̶/8̶" s̶i̶n̶g̶l̶e̶ s̶p̶e̶e̶d̶ (̶P̶C̶1̶)̶ c̶h̶a̶i̶n̶
stock Bafang 46T chainwheel
Shimano-Nexus 3-speed IGH
Ego 56v 5Ah
Greenworks 60v, 4aH and 5aH
Echo 56v 5aH
999zip999   100 GW
Post by 999zip999 » Jan 03 2023 5:54pm
What happened to the lower right hand corner of that battery it looks rusted is it leaking has it leaked ?
Used batteries are a big gamble.
torker   1 MW
Post by torker » Jan 05 2023 12:11pm
999zip999 wrote:
Jan 03 2023 5:54pm
No. That is just gooey foam tape they used during manufacture.
Bbbbrass   10 mW
Post by Bbbbrass » Jan 06 2023 1:33pm
See if you can find some cheap lawn tool batteries! Ryobi 40V work great, and there are several adaptors on Amazon. You can also use Kobalt or Greenworks 40V. Pretty much any of them will give you enough power.
Cheap Amazon 52V 1000W (36V 750W) front hub motor, DIY 14S5P recycled 25R pack with JBD BMS (30A max, 52V, 12Ah)[10S3P recycled Dyson 20700 pack (7.5Ah usable)], DIY mixed 20/1700 pack Dyson & LG 14S4P 30A max, 52V, 10Ah, mounted on an old Diamondback Outlook with super shitty brakes, CA V3.1, and AMAZING SPL-01 headlight.
