As a result I make all of my own products where at all possible, corrosion inhibitors, shampoo, conditioner, antifungal creams, antibiotics creams, essentially if there's a chemical product you'd normally go to the hardware store or pharmacy for I have spent years formulating and testing my own alternatives.
This one I've been playing with over the course of two winters, last winter was mostly research and some prototyping but after a season of extreme conditions I'm excited to announce that it's pretty well perfected!
Things you will need:
Golden Jojoba Oil - 5%
Xanthan Gum - 2%
Allantoin powder - 0.5%
(alternatively you can use a quality Comfrey extract or a Comfrey Lactoferment, the ferment will need to be filtered very well. (Fermentation helps solubilize the allantoin in the Comfrey but allantoin is quite cheap as readily available online)
Pure Lavender Essential Oil - 1%
99% Isopropyl Alcohol - 30% ( or 90% grain alcohol if you have access, methanol would also work but is nasty stuff.)
58% water (distilled is best, chlorine is not helpful)
Mix the Xanthan Gum, JoJoba Oil, Allantoin, lavender oil and HALF the Alcohol together thoroughly. A blender or hand blender is helpful here.
Once mixed add water slowly while continuing to blend until the mixture transforms from a liquid to a thick paste. At this point slowly add the rest of the alcohol while continuing to blend until the mixture is once again a runny consistency albeit thicker than before.
Add the rest of the water while blending to bring it up to volume and put it in a pressure sprayer or high quality hand sprayer.
Spray down the bike thoroughly, grab a microfiber cloth and wipe off the excess before it dries.
The remainder will dry to a solid thin non sticky layer that clings tightly to the metal and paint of the bike, when water hits it the top layer absorbs the moisture and it becomes a super lubricant.
The allantoin, lavender oil and jojoba oil all cause strong chemical reactions with aluminum and steel that inhibit corrosion and the xanthan Gum causes a strong corrosion inhibiting physical reaction on top of providing superior lubrication under torque.
A single application will stay on for a solid month riding through the nastiest salty mud puddles.
Hopefully this helps some other winter riders as much as it's helped me
(I'll make a more detailed write-up and explanation of the different properties the mixture has when I've got some more time, in a rush this morning just wanted to share after the tremendous help I've received from you all )
