there is NO throttle or e-brakes available for the 6 pin model
$45 or best offer, shipped CONNUS.
I have several new unused for sale.
Be sure to check the connector end on your current motor/controller system to verify if it has 6 pins. You will need to match it to install the VLCD-5 Display. This Display is ONLY COMPATIBLE WITH TSDZ2 SYSTEMS THAT HAVE A 6 PIN CONNECTOR!
*FOR THE 8 PIN MODEL BUNDLED WITH THROTTLE AND E-BRAKES, SEE THIS AD
The VLCD-5 Display - Large Center Mount Display w/ USB & More:
The VLCD-5 is a larger, center mounted display with ports for a throttle, e-brakes, and an external handlebar mounted button panel. This keeps wiring clutter down as only a single wire is needed to run from your motor to your cockpit/display, then the throttle and brakes stem from that. The VLCD-5 also houses a USB port for charging your mobile device.
The throttle port is only wired in the 8 pin model - there is NO throttle or e-brakes available for the 6 pin model (no wires connected internally to the throttle port). It is also noteworthy that installation/use of the throttle, e-brakes, and/or external button panel is completely optional. If you have high rise handlebars or a trike etc, and need extensions for the throttle, brakes, or button panel - we offer those as well.
The controls are on the display as well as the handle bar mount panel ~ featuring +\- buttons to adjust the level of assist, a power button that doubles as on/off for the lights with a short press, and an information button to toggle the trip/odometer readout. There is also a 'hidden menu' where you can adjust the settings for wheel diameter, change the speed limit, switch between miles or kph, and more. The VLCD-5 display screen face is removable from its mount by pressing a tab underneath the USB port.
Be sure to check the connector end on your current motor/controller system to verify if it has 6 or 8 pins. You will need to match it to install the VLCD-5 Display.
New OEM TSDZ2 display 6 pin
- Attachments
- Screen Shot 2023-02-01 at 11.56.49 AM.png (707.02 KiB) Viewed 4772 times
