Show off your Ebike creation here.
Elektrosherpa   1 kW
Re: Your Creation's Before & After Pics
Post by Elektrosherpa » Jul 24 2021 5:16pm
nicochise wrote:
Apr 16 2021 11:53pm
That looks awesome :bigthumb:
I bet my 4-pawed-companion would prefer such a comfortable place, too...
My Build (Bultaco Sherpa T350 -> QS138H70) :
viewtopic.php?f=12&t=110352
senlin   1 W
1 W
Post by senlin » Jul 24 2021 11:18pm
nicobie wrote:
Jul 24 2021 3:28pm
Now that's something we've yet to see on ES.
Cool bike. Well done. Just watch out for those sharp corners!
Ha Ha, Yeah, turning circle is definitely not good!
senlin   1 W
1 W
Post by senlin » Jul 24 2021 11:22pm
Greendog wrote:
Jul 24 2021 5:01pm
Rad bike, don't think wheel base is long enough though :wink: good luck trying to pull wheelies on that :lol: jokeing aside, bet is very quick of the line, just imagine how much beer you could carry if it had side storage and with that much torque trailer full to , :mrgreen:
Thanks Greendog, it's a good idea, would make a good beer hauler. Actually the LTO batteries remind me a bit of thin long beer cans :D
senlin   1 W
1 W
Post by senlin » Jul 24 2021 11:25pm
Elektrosherpa wrote:
Jul 24 2021 5:08pm
senlin wrote:
Jul 24 2021 5:55am
Tandem Titanate 2WD.
Crazy build. :bigthumb:
In my eyes, all the free space behind the rider just waits to be used:
2nd seat, storage space, dog place... whatever... :wink:
Actually I've got a big German shepard Mastiff X, mmmm now you've got me thinking :P
ford   1 µW
Post by ford » Jul 31 2021 9:17am
Audisport09 wrote:
Jul 07 2021 5:06am
Finished :)Bikke.jpg
This is one of the coolest ebikes I’ve seen. I love it ! Nice work.
MattZ   100 W
Post by MattZ » Aug 04 2021 8:34am
First post, first build
Thanks to everyone on the site for the knowledge I've gained reading your discussions. You made this project possible, and successful (so far).
Decided to build a couple ebikes for me & my wife. Hers is first, the parts for mine should be here soon.
Before:
After:
QS 1200w DD hub motor
KT 36/48v 15A controller
48v 20Ah rack mount battery
Added rear disc brake, new shifters, headlight, springy seat post, kickstand, comfy seat.
She's loving it, 50 miles on it so far.
moonkagliwicee   100 mW
Post by moonkagliwicee » Aug 05 2021 12:22pm
Project "Dark eCruiser". Johnny Loco Sinatra frame. Other parts from Electra Cruiser
drguitar   10 mW
Post by drguitar » Aug 08 2021 7:12pm
Schwinn Glenwood.jpeg (263.21 KiB) Viewed 4031 times
Steel frame, 700/32 tires, mechanical disc brakes, spring fork shock
Added:
BBSHD kit
48v/24.5ah battery
Hydraulic brakes
Continental Contact Plus tires 700/47
Seatpost shock
11t-34t freewheel
Deore 7 speed derailleur
Thumb shifter
Adjustable steering stem
Mid-rise handlebar
Rechargable headlight 600 lumen
Rechargable rear tail light and 100 db motion alarm
Rear rack
Schwinn e-bike.jpg (619.98 KiB) Viewed 4031 times
“It is not uncommon for the cyclist to remark, wheeling is just like flying!
James Howard Means
thundercamel   10 kW
Post by thundercamel » Aug 08 2021 7:44pm
Nice job! It's a very similar bike to the most recent one I've converted (for my father in law) in my build thread below. Were the brake pads on yours also too far away from the axle to have all of their area swept by the rotor? I find that to be the case on several bikes I work on, and usually remove washers to move the calipers closer to the axle.
My Ebike builds - Existing bikes, affordable motor kits, self built 14s6p batteries - Now with more recumbent!
drguitar   10 mW
Post by drguitar » Aug 08 2021 8:41pm
thundercamel wrote:
Aug 08 2021 7:44pm
Were the brake pads on yours also to far away from the axle to have all of their area swept by the rotor? I find that to be the case on several bikes I work on, and usually remove washers to move the calipers closer to the axle.
I was lucky and the new calipers fit nearly perfectly where the previous calipers were. A little adjustment and the wheels spin freely and stop with little effort. :thumb:
James Howard Means
Chalo   100 GW
Post by Chalo » Aug 08 2021 10:33pm
The build seems reasonably okay from what I can see. The bike is horrible and will quickly make you regret using it.
If you're the first person who cared at all about the bike, or spent a nickel on it that wasn't minimally necessary, maybe ask yourself why. That kind of bike can be fixed up, but what's wrong with it can't be fixed.
drguitar   10 mW
Post by drguitar » Aug 09 2021 6:14am
Chalo wrote:
Aug 08 2021 10:33pm
Yep, you may be right. However, the part of the bike I wanted is the part I kept; the steel frame. I carefully inspected all the welds before starting and it looks good. Plus the steel frame makes for a very sturdy build. And after putting a few hundred very comfortable miles on it, I am enjoying it very much. Is there something specific about the frame you see as a problem or are you just throwing shade because you can?
James Howard Means
Chalo   100 GW
Post by Chalo » Aug 09 2021 9:59am
drguitar wrote:
Aug 09 2021 6:14am
You kept the fork, which is a very nasty piece of work. Not only do those things develop rusty stanchions very quickly, but they have plastic bushings. It takes very little time for them to develop a lot of looseness and play. The only damping they have is from sliding friction, which becomes more and more inconsistent as they wear (alternating at random between no damping at all, or binding and effectively being locked out). Putting decent brake on this fork is harder on the bushings than the lame stock brake would have been.
The steel used in the frame is chosen only for being cheap, so it's a crapshoot. I've come across some whose dropouts bend out of alignment if you look at them wrong, and others with extremely strong dropouts that are difficult to align, but were out of alignment to start with. The frame tubing is usually pretty soft, but often so thick and heavy that it does the job (at pedal bike speeds anyway). But BSO frames are seldom straight, and to this day many of them use front opening horizontal dropouts so that the wheel can be fudged more or less to center despite the rear stays not being centered.
I have come across BSOs with frames that didn't have any obvious problems. Maybe you got one of those-- we can hope. I've never seen a single one of those forks that wasn't a clunky awful mess after any significant use, though.
You did a good job on the conversion, and it would be nice if the bike didn't let you down. Just take heed that letting you down is what BSOs do in their retirement after finishing the only job they were designed for-- getting you to hand over money for them.
drguitar   10 mW
Post by drguitar » Aug 09 2021 2:09pm
Chalo wrote:
Aug 09 2021 9:59am
Yep. That is why the front fork is probably the first thing I will upgrade when it starts to act up. As of right now, it is working well with no lateral (side to side or front to back) play in the front wheel.
Chalo wrote:
Aug 09 2021 9:59am
I've tried conversions on LSOs (Llama Shaped Objects) and FSOs (Flower Shaped Objects), but the only conversions that really worked were on BSOs. The first BSOs were Treks and Giants, but they had aluminum frames which seemed possibly problematic down the road as the aluminum weakens from repeated stress. As with each of the bikes I converted, I checked the frame for solid welds and straight dropouts (and derailleur hangers). So far, this Schwinn has come through with flying colors. The dropouts are solid, the bike feels solid at 30mph (no twisting to the frame and no shimmies or shakes), and the hanger is dead straight (shifting is smooth and even).
Chalo wrote:
Aug 09 2021 9:59am
Thanks, I am really enjoying it. I realize that cheap frames are just that, cheap. But a cheap steel frame seemed like it might work as long as there were not any measurable or visual problems. The hardware on the bike is quite lousy, but most of that has been replaced. Even the races for the bearings in the wheels were not completely smooth (a little work corrected that). So although the bike is cheap and cheaply made, it is bicycle shaped which allows me to make it run/ride nicer than it was when it came out of the BSO factory. :wink:
James Howard Means
thundercamel   10 kW
Post by thundercamel » Aug 11 2021 11:09am
drguitar wrote:
Aug 08 2021 8:41pm
You're right, I've had fine luck with hydraulic brakes, and was referring to the original brake calipers. I missed that you upgraded in my first read through.
drguitar   10 mW
Post by drguitar » Aug 11 2021 3:53pm
thundercamel wrote:
Aug 11 2021 11:09am
No problem. I'm digging the hybrid hydraulic brakes (brake cable to the caliper with hydraulic fluid in the caliper only). It took a day or two till I figured out how to properly adjust the caliper; it first it had no grab at all. Then I found the piston adjuster and that made all the difference!
Anyway, I realize that my BSO (Bike Shaped Object or Bull Shit Opinion) frame is not a particularly expensive steel frame (cheaper than dirt), but it seems to be quite sturdy and I am enjoying it a lot. The bike is quite tall at 54 inches to the top of the handle bars and it feels tall when riding it, but it is very comfortable, and fun standing on the pedals, floating over the street at nearly 7 feet in the air.
James Howard Means
thundercamel   10 kW
Post by thundercamel » Aug 12 2021 8:46pm
Plenty of us including myself are not bike snobs and love cheap department store bikes as a starting point :wink: In my opinion any ebike with pedals is a step in the right direction.
drguitar   10 mW
Post by drguitar » Aug 12 2021 8:55pm
thundercamel wrote:
Aug 12 2021 8:46pm
... any ebike with pedals is a step in the right direction.
I love the pun!
James Howard Means
ZeroEm   100 MW
Post by ZeroEm » Aug 13 2021 12:09pm
No snob here. Have a Kent tandem bike on the way $230 with shipping. That"s cheap. Will try to make a road recumbent out of it. Wanted it for the load capacity. Will need to replace all the cheapest parts with better ones.
2019 Performer E-Trike
2013 Nissan Leaf S 7 bars 331.5w/KM
TrotterBob   100 W
Post by TrotterBob » Aug 13 2021 1:27pm
thundercamel wrote:
Aug 12 2021 8:46pm
As I understand it, steel frames and forks are an advantage if your setup will give more grunt than a well seasoned cyclist. They stand up to abuse more.
drguitar   10 mW
Post by drguitar » Aug 13 2021 8:31pm
ZeroEm wrote:
Aug 13 2021 12:09pm
Sounds cool. Definitely post pics when done.
James Howard Means
drguitar   10 mW
Post by drguitar » Aug 13 2021 8:33pm
TrotterBob wrote:
Aug 13 2021 1:27pm
That's what I read also. That is why I took the BBSHD off an aluminum Trek and put it on a steel Schwinn.
James Howard Means
electric_nz   100 W
Post by electric_nz » Aug 25 2021 12:17am
So I bought a brand new ‘parts bike’ Juiced ODK U500 v3 from a local delivery company. Never been used but missing controller and the battery had been swapped for a dead one. Bike has a Bafang BPM 48V/500W that is pushing 1000W from the factory!
Instead of paying the crazy OEM spare part costs, thought I’d DIY and shoehorn the replacement controller inside the massive battery box, without cutting any new holes. I built a small aluminium frame to fit a KT S09P-BL 9FEt sensorless controller with a speedict Neptune 15 BMS. Batteries were salvage 4p14s Samsung 29E constructed from 2 36V packs cut up. (don’t need a huge range). Connectors, controller and other parts were from bmsbattery.com. It’s using a large 3 way connector for phase and USB for throttle. Goes surprisingly well and climbs steep hills with no complaints from the passenger compartment!
thundercamel   10 kW
Post by thundercamel » Aug 26 2021 10:03am
That's a nice slide in module you've made there :)
