I didnt realise you had the fighter, I thought it was a bomber. In which case you'll need those extra voltsvoicecoils wrote:My Fighter? For sure! (*goes off to rewire packs for higher voltage*).
Is Tony two stroke a kitted up bicycle or motor bike ?
I've got a little 160cc pit bike that I'd love to put up against my bike or a bomber. I reckon it'd be pretty close up to ~60ks where they start to run out of puff. Is your fighter up and running now ? We'll have to organise a get together shortly.
I thought it was nice and it certainly keeps things neat and integrated. Personally though, for what they cost I couldn't justify the expense over a rear derailleur set up considering I very rarely shift out of top gear. With several kw on tap I imagine it'd take alot to self restraint to shift down gears and pedal harder rather that just using the throttle to blast you back up comfortable pedalling speed in top gear.What did you think of the 9 speed gearbox?
John mentioned having Kepler torture his bomber provides good R&D info for him. I've dubbed him 'Kepler the Canary' as I'm sure John is waiting for him to fall off the perch so he can see what the bombers can really takeHot rodding is an easy one for the geeks & that doesn't change the lifetime warranty on the Stealth frames.
