Wobbly Cyclone Bracket Cure.
Hugh-Jassman   1 kW
Post by Hugh-Jassman » Mar 09 2019 2:40pm
When I got this mid-drive kit I looked around to find an image by DingusMcgee of a bracket that would hold it rock steady. Then I built my own version. Angle bar and flat bars with bolts holds it very steady. But it is the tube between the two flat plates that makes it wobble proof. So if you have a Cyclone Mini just find a tube that will fit and bolt the two plates together with low headed carriage bolts, to give you room for chain rings.
The shape of the tube does not matter as long as it fits. And it needs to be wide enough to suport a wider area than a one inch round tube would.
Breacket mounting bottom view.JPG (277 KiB) Viewed 98 times
I try to think outside of the box; But when I look out the window, I don't understand what I see.
markz   100 GW
Re: Wobbly Cyclone Bracket Cure.
Post by markz » Mar 09 2019 11:21pm
Hugh-Jassman wrote:
Mar 09 2019 2:40pm
wobble proof
:thumb:
And aluminum makes it light! :wink:
Hugh-Jassman   1 kW
Post by Hugh-Jassman » Apr 10 2019 12:50pm
I used aluminum for ease of cutting and filing. It is simular to wood without the grain. 2024 or 6061 alloy
https://www.onlinemetals.com/en/buy/alu ... al/pid/988
markz   100 GW
Post by markz » Apr 11 2019 4:11pm
Manly man slivers are metal, not dead wood carcass as that fella on Youtube Channel AvE states.
Hugh-Jassman wrote:
Apr 10 2019 12:50pm
I used aluminum
simular to wood
Hugh-Jassman   1 kW
Post by Hugh-Jassman » Apr 15 2019 1:53pm
markz wrote:
Apr 11 2019 4:11pm
Hugh-Jassman wrote:
Apr 10 2019 12:50pm
I used aluminum
simular to wood
markz   100 GW
Post by markz » Apr 15 2019 7:31pm
It was a joke, saying how manly it was to use metal and how not manly it is to use wood. Just reminded me of this channel
https://www.youtube.com/user/arduinoversusevil
Hugh-Jassman wrote:
Apr 15 2019 1:53pm
markz wrote:
Apr 11 2019 4:11pm
Hugh-Jassman wrote:
Apr 10 2019 12:50pm
I used aluminum
simular to wood
