maarkmohamed
- Joined
- Jan 10, 2019
- Messages
- 114
Quick question, i have a 72v battery nominal and the bac8000 controller, when i go to connect the terminal from the battery to the controller theres a spark which is expected. However it causes a bit of a burn on the connector as seen in the image and would like to avoid that. Now its only going to be connected and disconnected a few times because it should stay on there permanently, but for the very few times i do connect and disconnect is there a solution for this? Was thinking maybe a resistor that i could put in between the terminal and controller connection temporarily but not sure exactly which one?
https://ibb.co/NZP0RKs
