Moving the brake caliper inwards
Dumsterdave   100 W
Post by Dumsterdave » Dec 23 2019 8:40am
I just put a rear hub onto a fat bike, but I have a problem... The existing caliper needs to move inwards (closer to the hub) by about 2 centimeters. Is there an adapter that will allow for this?
Skorohod   100 W
Re: Moving the brake caliper inwards
Post by Skorohod » Dec 24 2019 6:22am
Dumsterdave wrote:
Dec 23 2019 8:40am
I've been in similar situation (not a fat bike and not a two centimeters, though). I've decided not to search for adapter but use a right amount of washers instead:
Teleport Medium, Nucular controller 12F + QS 205 v3 50H 8T, 20s28p NCA32 18650 battery, DNM USD-8 fork.
goatman   100 kW
Post by goatman » Dec 24 2019 1:11pm
you can use a chunk of 3/4x3/4 aluminum bar or square tube, cut to length and drill 2 holes. you can machine aluminum with a skill saw and carbide blade. so if you have a chunk of aluminum, a drill and a skill saw and a belt sander, you can machine, plane, sand any shape you want
Voltron   10 MW
Post by Voltron » Dec 24 2019 1:37pm
Sometimes it's better to move the rotor out with a spacer, but you may need slightly longer bolts too. Don't use a plastic spacer that comes with some motors.. That's just to keep the bolts from going in too far to the motor case while no rotor is mounted... It's too mushy for actual spacer-ing.
Edit...I just reread 2cm... Maybe some of both... Spacer the caliper in and the rotor out?
amberwolf   100 GW
Post by amberwolf » Dec 25 2019 2:16am
Moving the caliper away from the frame with washers means repeated shear loading on the bolts. Depending on the bolts, etc., the repeated bending back and forth has the potential to break them and leave you unable to brake (or to have the caliper get tangled up in the rotor and lockup the wheel).
Spacing the rotor away from the motor, with the right kind of spacer and sufficient bolt pressure, has a different kind of loading on that extension, which is unlikely to fail in the same way. Spacers for this purpose specifically are commonly available, as are longer bolts.
So if I were doing it, I'd put the spacers on the rotor, not the caliper, though 2cm is quite a distance.
Punx0r   100 GW
Post by Punx0r » Dec 25 2019 9:21am
In my experince 1cm spacing on both rotor and caliper works fine on a back disc brake.
Dumsterdave   100 W
Post by Dumsterdave » Dec 26 2019 4:42pm
Voltron wrote:
Dec 24 2019 1:37pm
Sometimes it's better to move the rotor out with a spacer, but you may need slightly longer bolts too. Don't use a plastic spacer that comes with some motors.. That's just to keep the bolts from going in too far to the motor case while no rotor is mounted... It's too mushy for actual spacer-ing.s-l300.jpg
Where can I find that 7mm spacer
Voltron   10 MW
Post by Voltron » Dec 26 2019 5:42pm
That was some random Google image... I've never needed to order one that big.
billvon   1 GW
1 GW
Post by billvon » Dec 26 2019 6:43pm
Dumsterdave wrote:
Dec 26 2019 4:42pm
I would note that some rotors (when adequately cut down) make excellent spacers.
--bill von
Punx0r   100 GW
Post by Punx0r » Dec 27 2019 4:54am
Fiddly, but stacks of washers (preferably taped together) will work. I'd rather use a spacer of some kind though.
aroundqube   1 kW
Post by aroundqube » Dec 28 2019 5:40pm
Dumsterdave wrote:
Dec 26 2019 4:42pm
Voltron wrote:
Dec 24 2019 1:37pm
Disc rotor spacers here : https://mbrebel.com/bike-parts/
