Screw stuck on battery
HarryC   100 µW
100 µW
Post by HarryC » Feb 21 2020 5:51am
Please can someone tell me how I can remove a stuck screw /
I have ruined the screw head by using the wrong screwdriver :( Any ideas how I can undo this?
I've got the right screwdriver now and I've tried spraying it with WD40 but it still won't budget. I'm hoping you guys might have some easy methods that I could try.
HK12K   10 kW
Re: Screw stuck on battery
Post by HK12K » Feb 21 2020 1:53pm
Pics would help, considering that we have no idea what battery you're talking about.
john61ct   100 GW
Post by john61ct » Feb 21 2020 2:39pm
you mean a bolt?
HarryC   100 µW
100 µW
Post by HarryC » Feb 27 2020 7:31am
Yeah its a small bolt, I couldn't upload a photo. I tried WD40 and then a rubber band and it didn't move much. I followed this video and got it out with a dab of superglue in the end : https://www.ifixit.com/Guide/How+to+Rem ... crew/13213
spinningmagnets   100 GW
Post by spinningmagnets » Feb 27 2020 12:00pm
Depending on how much meat is left on it, I'd use a dremel with a thin abrasive disc to cut a slot across the head. If a straight screwdriver wont rotate it out, I'd use the dremel to grind the head completely off.
John in CR   100 GW
Post by John in CR » Feb 27 2020 12:37pm
HarryC wrote:
Feb 27 2020 7:31am
So the superglue technique worked. Thanks for sharing. I never would have thought to try that one.
Regarding WD40, it's never worked for me, and I saw a video of tests of several products that confirmed its ineffectiveness. Sure it has lots of other uses, but since it's a Water Displacement spray (thus the WD) not a penetrating oil, don't waste time using it to get a bolt unstuck. Down here there's a product called Break Away that works almost every time for me. Really tough to remove threaded parts often require patience to get enough penetration to be helpful.
HK12K   10 kW
Post by HK12K » Feb 27 2020 12:46pm
Fwiw they do sell a full line of "specialist" products under the WD-40 label that aren't actually the original WD-40. Just happen to have a can of their dry lube PTFE spray sitting next to me here, which I quite like.
aroundqube   1 kW
Post by aroundqube » Feb 27 2020 7:21pm
I have had good results, many times, using long nose locking pliers ; https://www.amazon.com/VISE-GRIP-Origin ... 41&sr=1-14
