Conradportelli
- Joined
- Jun 19, 2020
- Messages
- 3
This is a battery pack I want to buildi just want to make sure I'm doing it right. It's 40 packs of lithium cells. Each pack is made of two cells at 2200mah 3.7v in parallel. The "yellow" wires in series is one of the issues. I'm not sure if I can just solder these wires together in series or if I should use short copper pieces to connect them. The four positive and the four negative ends at the beginning and end of each series I will connect with long pieces of copper to make my discharge/charge terminals. Oh I should mention that each cell has its own bms.
