AussieJester
1 TW
I just received delivery (7.10PM at night mind you!!!) of a
couple of infineon controllers, neither of them
are mine i'm simply forwarding them on for a couple of mates, but
i simply had to show the packaging that these came in i have never
before seen so much care taken, credit where credits due, check this out-->
OVER SEVEN foot of bubble wrap for TWO Infineon 12fet controllers
Mr Lyen YOU PWN packaging SiR As you can also see there is more than
AMPLE foam noodles, SO if ANYONE receives a damaged Lyen Controller you can
be assured it ain't Mr Lyens fault!
Cheers Mr Lyen..
KiM
p.s I must also add i have received a few packages from Mr Recumpence SiR
and he is a VERY VERY close second to this degree of packaging VERY close...
top job fellas i wish every parcel i received was packed so well!
Cheers Mr Lyen..
KiM
