Page 1 of 3
Re: Brushless Motor Controller repair
Posted: Feb 20 2012 11:03pm
by august23
I am interested in doing self repair on MAC and BMC motors w/internal controllers. I would also like to know how to bypass the internal controller. I believe I could probably figure it out on my own, but some literature could save me some serious time. schematics, instructions, howtos.... anything. can anyone help? or at the very least direct me to someone local who can help?
thankyou very much!
august
Posted: Feb 20 2012 11:28pm
by DAND214
Are you sure they have internal controllers? I have both and they don't. I think you need to do some more resurch.
Dan
Posted: Feb 21 2012 11:35am
by august23
lol yes im sure. are you sure dan? anyway, thank you for the help.
Posted: Feb 21 2012 11:59am
by august23
here is one of the motors in question.
http://www.monsterscooterparts.com/24-v ... -1318.html
How to bypass internal controller on brushless motors?
Posted: Feb 21 2012 11:07pm
by august23
thankyou very much!
august
example: http://www.monsterscooterparts.com/24-v ... -1318.html
Posted: Feb 21 2012 11:09pm
by august23
thankyou very much!
august
Re: How to bypass internal controller on brushless motors?
Posted: Feb 22 2012 1:29am
by Kin
I'll be honest, your post doesn't make any sense to me.
Not sure what bypass controller means. Do you mean increase the power it puts out? That can be done, at risk of damaging it.
Bypass the controller, and apply voltage? On the MAC/BMC motors as far as I'm aware they're all brushless. That's a problem; you can't just apply DC to them.
Yeah, but, try to write out
1) What you're trying to do
2) What you already know
3) what ideas you have.
Your post really didnt make sense.
Posted: Feb 22 2012 1:33am
by Kin
I read one of your other posts that made some more sense to me.
So you know the small silver box that the motor originally connects? That is the controller. Its not an internal one.
It is brushed though, so applying a DC power source will make the motor spin. Maybe thats why you think there is an internal controller.
You can usually quite easily connect these to a replacement brushed motor controller. It should run $30-40 dollars on most of these replacement websites, though they're not too complicated.
I'm talking about something that looks like the silver box next to the motor in the link I'm showing:
http://www.thesuperkids.com/600wabrcuels.html
But the link is absolutely just the first thing I found. Might not apply at all to your situation, except that your controller will almost certainly look the same.
Posted: Feb 22 2012 2:08am
by august23
Ok I can see how it might not make sense. you would have to know more about the motors in question. the motors I am referring to are a line of brushless motors from BMC (http://bmcus.com/bldc.htm) and MAC(http://www.macmc.com/macbmchome.htm) that have the controllers built in. I am aware of the external stepping controllers you are referring to for brushed motors as I have 5 different ones w/different configs. These motors are NOT the same. you only need power and a 5k ohm Pot to operate these MAC/BMC ones. and I do understand that MAC/BMC do make motors with/for external controllers (obviously)... and brushed motors too. but never mind all those other ones.....
What I have learned is that several of these motors (specifically the 24v 600w MAC motor) have been designed around much higher specs, but used downsized controllers in them instead for whatever reason (probably quality control). If you look at this page (http://www.thesuperkids.com/600wahspsuto.html) what you are actually seeing is this product (http://www.thesuperkids.com/600wasutocum.html) which has been factory by passed and relabeled as a 1000w brushless and controllerless motor, paired up with a custom 3rd party controller. I confirmed this with superkids personally. The controller they are selling comes from this company (http://www.crystalyte.com/Control.htm) which are designed for wheel hub bike motors (brushless again of course).
What I would like to do is to basically copy what superkids are doing (http://www.thesuperkids.com/600wahspsuto.html). Why? I have access to a bunch of these motors with burned out internal controllers... AND why repair them when I can 'upgrade' them by bypassing the burned out (presumably) internal controllers and rewiring them for one of these external controllers (http://www.crystalyte.com/Control.htm).
from what I have gathered on wiki (http://en.wikipedia.org/wiki/Brushless_ ... tric_motor), these are sensorless motors (non hall-effect). but aside from having taken several electronics classes in highschool and collage and some educated guessing, I dont really know where to start with out schematics or something. I'm going to take apart one of these to see what I am looking at. I did find another post of someone trying to do this but its a little old and not very useful.(http://visforvoltage.org/forum/8729-nee ... ment-63997). I might just be able to repair it... which would certainly be cheaper.... but easier? not sure yet.
does this clear it up a bit?
Thanks again
August
Posted: Feb 22 2012 8:39am
by Kin
It does! I am happy that what you're doing sounds like a possibility. In the few threads I saw some stuff about brushed motors, and thought you were very confused.
For what its worth, I think this might depend in part on how to take apart the motor safely. You should have wires going into the motor if has an internal controller, and if you follow those, presumably you will get to an internal controller. There's a chance it's epoxied in, which will be hard to deal with. But if you're lucky you will simply be able to remove the internal controller. The internal controller will still work the same way, and have three wires go to the motor. Those might need to be extended, but if you extend them out of the motor with new longer wires [use thick gauge for these 'phase wires'] and you'll be in a good position to wire up an external controller. I do not think there should be any problems with this, but I would search endless-sphere for some of the magic pie mods. I think if you can't find the mods for the BMC you speak of, you are likely to find some about Magic Pie, another company that sold internal and external controller motors. Plenty of people had their internal one blow, and had to replace it with an external one.
Posted: Feb 22 2012 8:50am
by Ykick
Hello august23 person, you mentioned finding someone local but you offer no location? Good luck with your project!
Posted: Feb 22 2012 9:41am
by fechter
You might find this thread helpful:
http://endless-sphere.com/forums/viewto ... 16&t=11772
I bypassed the internal controller on my BMC long ago. It's not that hard but depending on how long they left the wires, soldering extensions can be challenging. With forced air cooling, I can run it at over 2kW.
Also keep in mind that not just any controller will work well with these motors due to the hall timing.
A sensorless controller avoids this problem and you don't need to worry about the hall wires, but finding a good sensorless controller is still difficult.
Posted: Feb 22 2012 12:23pm
by august23
fechter wrote:You might find this thread helpful:
ah so these ARE hallsensored motors? that might explain why I see more than 5 wires in the pic of the already by passed 600w MAC motor. Thank you!!!!
Posted: Feb 22 2012 12:24pm
by august23
Ykick wrote:Hello august23 person, you mentioned finding someone local but you offer no location? Good luck with your project!
Oh! oops
Minneapolis MN
Posted: Feb 22 2012 12:27pm
by august23
Kin wrote:It does! I am happy that what you're doing sounds like a possibility. In the few threads I saw some stuff about brushed motors, and thought you were very confused.
that is very helpful!!! thankyou. I'll def look into magic pie (first I have heard of them/it)
thank you again.
re repair: any tips to diagnosing internal controllers?
re bypass: any tips for knowing which phase lead is which?
Posted: Feb 22 2012 12:29pm
by august23
I looked hard and long for a page just like that... what key words did you use? excellent find!!!! thanx
Posted: Feb 22 2012 12:42pm
by august23
you the man!!!!
Posted: Feb 22 2012 12:54pm
by Kin
I think he might not have needed to use keywords :). That was his thread; he was the one who replaced his internal controller.
I don't know if you tried google, but often that helps find things better than the forum search engine. google "blah blah blah endless-sphere.com" (without quotes) and you typically get better results.
Posted: Feb 22 2012 3:57pm
by fechter
Actually, I tried using the forum's search function knowing the thread was there. It did not find it. Forum search sucks. I found it by exercising the few remaining brain cells and remembered where I put it originally.
The Google domain search is much more effective.
Posted: Feb 22 2012 8:00pm
by august23
I should have figured that out. ah I assumed the search function on here was sufficient. and in case you didn't know: the easiest way to seach a domain on google is like this:
site:endless-sphere.com keyword1 keyword2
example:
site:endless-sphere.com (this would show every page index google has on the site)
site:endless-sphere.com BMC bypass (this would show everypage that has BOTH key words in it. (About 234 results))
thanks folks!
Posted: Feb 22 2012 8:04pm
by august23
fechter wrote:Actually, I tried using the forum's search function knowing the thread was there. It did not find it. Forum search sucks. I found it by exercising the few remaining brain cells and remembered where I put it originally.
fletch you have been busy:
https://www.google.com/search?num=20&hl ... 4l7.7l14l0
Posted: Feb 22 2012 8:49pm
by friedwires
i boiled the controllers out of the ones i've done http://64.64.13.141/forums/viewtopic.php?f=2&t=17404 http://64.64.13.141/forums/viewtopic.php?f=28&t=32059 i need to update my mongoose thread, the bike is a little monster!
Posted: Feb 22 2012 9:40pm
by august23
friedwires wrote:i boiled the controllers out of the ones i've done http://64.64.13.141/forums/viewtopic.php?f=2&t=17404 http://64.64.13.141/forums/viewtopic.php?f=28&t=32059 i need to update my mongoose thread, the bike is a little monster!
yeah I saw that on some other thread.. but it wasn't as complete as these 2. from what I can tell, it's not necessary to completely remove the old controller. though I like those nice long wires you managed to extract!
any ideas on what kind of ribbon I'll need for the hall effect wires?
and where did you get your replacement controller?
Posted: Feb 22 2012 9:44pm
by august23
also, I didn't see any wiring diagrams. can you help?
Posted: Feb 22 2012 10:21pm
by friedwires
forget repairing the original controller. its fully potted, making it impossible to work on. what you need to do is get that controller out of there. there are three pairs of large wires(phase wires) and a five wire ribbon(halls wires) you need to get to them without damaging them so you can solder to them and bring the wires outside the motor. i found the best way is to get the controller right out of the way. boiling will soften the potting enough for you to dig it out to get at the screws that fasten the controller to the inside of the face plate.once the screws are out,you can pry up under the circuit board and break it out of there piece by piece with pliers. as far as wiring diagrams go you're gonna have to wing it. i may have kept some notes somewhere but either way we can walk you through it. i would recommend a lyen 12 fet controller for this motor,and i'd also recommend running at 48-60v
