Nehmo
The handlebar mounted mirror arrangement has the drawback of being below the normal field of view. A rider needs to look down and them adjust her or his head position, all the while the rider's attention needs to be forward.
An additional problem with this arrangement is that the mirror's position, tied to a steering member, is dictated by the needs of steering - not the needs of visual efficiency. The mirror needs a more stable position.
One alternative is a helmet mounted mirror. I don't understand why they didn't catch on. I hardly ever see anybody with one.
I use a yellow construction hard-hat as a bike-helmet. I recently attached a 5 cm diameter inspection mirror (with a telescoping handle) to the side of the helmet to use as a rear-view mirror.
To attach, I used a plastic tie and radiator-hose tape. This will suffice until I can devise a more elegant method.
It works. It takes a while getting used to, but I’m beginning to think all other bike rearview mirror arrangements are inferior.
