World's first ROLT (electric lawn tractor)
Tommy   10 W
Post by Tommy » Oct 17 2013 5:50am
DIY ROLT
Remotely
Operated
Lawn
Tractor
It mows, plows, sweeps and hauls mostly from the comforts of my living room(remotely operated using cameras)
Tommy
dogman dan   100 GW
Re: World's first ROLT (electric lawn tractor)
Post by dogman dan » Oct 17 2013 6:54am
Just what I need, even with my tiny desert back lawn my post viral fatigue makes pushing a feather light electric mower a burden. Anything that's work that lasts longer than 30 min too much for me.
But if you have a remote control lawnmower, you simply must see this.
http://www.youtube.com/watch?v=7B49Jdlo7ns
Or at least the part between 5 and 5.30 min.
kfong   1 MW
Post by kfong » Oct 17 2013 7:50am
Nice, haven't had much chance to work on mine. Maybe this winter. What video setup are you using.
FeralDog   100 W
Post by FeralDog » Oct 17 2013 11:13am
Add the camera, and it is going to get its own reality show on cable TV .
The fingers   100 GW
Post by The fingers » Oct 17 2013 1:11pm
Cool machine. 8) Is it an adaptation of a shopping cart mule with an electric mower deck? Since I dont have a real grass lawn, all I would need is a used Roomba for vacuuming up the chihuahua droppings. :lol:
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
John in CR   100 GW
Post by John in CR » Oct 17 2013 4:55pm
How much including shipping to Costa Rica? Our back yard includes a small soccer field, so you can imagine the grass growing with the tropical sun during rainy season.
teklektik   10 GW
Post by teklektik » Oct 17 2013 5:19pm
John in CR wrote:How much including shipping to Costa Rica?
A quickie solar panel Bimini top for charging and you're all set!
Tommy   10 W
Post by Tommy » Oct 17 2013 6:09pm
dogman, as is my ROLT has a five hour run time on the Mower attachment(42"), here in wisconsin each season bring
a new set of challenges, we are currently going from mowing to picking up dead leaves, the sweeper in picture below
is hours of entertainment.
because I plow snow and pick up dead leaves on public roads I have to take extra care with the Rolt's safety systems.
kfong, I use five IP cameras, two are wired(because the DLink cameras suck bandwidth) and three are Wifi(Linksys cameras do a little better).
the router is mounted on the ROLT.
John in CR, it well be better when it's completed, it has a CNC mode, where you program the cut path, but until I get the beacons working
I have to start the program in the same spot each time, and finish around the boarders manually by FPV mode. I design it to mow a small
grass strip airport runway, should do a soccer field just fine.
Tommy
beast775   100 kW
Post by beast775 » Oct 17 2013 7:03pm
Thats dang cool!
2 FINGER SALUTE TO ESSO.no buying gasoline for 14 years now.
I spent all my money on bicycles women and beer the rest i just wasted.
Hillhater   100 GW
Post by Hillhater » Oct 21 2013 6:57pm
Tommy wrote: as is my ROLT has a five hour run time on the Mower attachment(42"),
.. I design it to mow a small grass strip airport runway, should do a soccer field just fine.
Incredible ! :shock:
would you care to share a few basics?.. motor drive system, power consumption, battery system, voltage, capacity, type, etc.
Any thoughts of going commercial with this design ?
Tommy   10 W
Post by Tommy » Oct 22 2013 9:00pm
Hillhater, I do like talking about this stuff.
The Motor drive system of the Rolt right now is two 24V 3000RPM 350Watt motors with electric brakes geared for a top
speed of 5MPH with the 18" turf safe tires, it has as an attachment two 1000Watt 3000RPM motors with 14" turf safe tires
that give it four wheel drive that I plan to use for plowing snow this season, with tire chains on all four wheels I should
have lots of fun this winter.
the mower deck that I designed for the airport has three 350Watt motors each motor drives a 20In. reel mower at 340RPM
with a cut path of 52In., the mower I use at home is two 1500Watt 24V rotary mowers and one 350Watt 14In. reel mower
to pick up the gap between the rotary mowers, next mowing season it'll be three 1500Watt 24V 17In. rotary mowers.
The batteries are in three groups, Rolt's drives and motors (24V, 2 150AH 12V batteries in series), Rolt's lights, cameras and computers (12V, 1 60AH deep cycle, there are currently three 100Watt inverters on the 12V group ), attachments like
Mowers and Sweeper (24V, four 55AH SLA currently).
not ready for prime time yet, I'm still working on picking up dead leaves and the beacon system while it looked good on
paper, it's not giving me the results I need.
Tommy
Hillhater   100 GW
Post by Hillhater » Oct 23 2013 12:50am
Tommy wrote: The Motor drive system of the Rolt right now is two 24V 3000RPM 350Watt motors with electric brakes geared for a top
Interesting, thanks Tommy.
So would they be Disability chair/buggy drives with their own drive controllers ( brushed motors ?)
I assume you are running a fixed drive speed ?
Tommy L   100 kW
Post by Tommy L » Oct 23 2013 5:42am
Hi Tommy!
This is Tommy L..... Could you update your profile to give your location?
Thank you!
Tommy L sends......Image
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy   10 W
Post by Tommy » Oct 25 2013 9:17pm
Hillhater, I'm currently using a Sabertooth 2X60 drive with analog input on the main axle, I have it set for mixing(differential steering)
so I have one analog voltage(0V= full reverse, 5V=full forwards with 2.5V = stop) for speed and one for direction, going to use the
roboclaw 2X60 for the rear attached axle because it has encoder inputs for better low speed velocity control on the direct drive wheels(14in).
Rear attached motors are 1000Watt four poled brushed, Main motors are 350Watt two poled brushed.
Tommy
Tommy   10 W
Post by Tommy » May 25 2014 5:47am
After three years, and exhausting all options I'v given up on the reel type mower.
while I'm sure there are environments that could accommodate the reel type, but
the environment my project has to deal with is not one of them. maybe a sod field
or golf coarse.
one apparent result is a sweet cut(first one ever). now using 3-20"(with 2" overlap)
24Vdc electric mowers which gives me a 54" cut path.
Tommy
arkmundi   1 GW
1 GW
Post by arkmundi » May 25 2014 6:11am
I admire your ingenuity and tenacity. Now, I'm sure every lawn owner's dream. If I get around to building my retirement home, putting in a septic system, therefore by necessity, a lawn, I may follow along your path building a lawn drone. Can we make one that picks weeds out of a garden?
Tommy   10 W
Post by Tommy » Nov 28 2019 10:43am
funny how projects change over the years.
today this project looks like
[youtube]https://www.youtube.com/watch?time_cont ... e=emb_logo[/youtube]
veloman   1 GW
1 GW
Post by veloman » Dec 03 2019 12:05pm
Awesome work.
I've been thinking of building a mini skid steer (all electric of course).
Mush! Mush you electrons! Push harder!
fechter   100 GW
Post by fechter » Dec 03 2019 3:15pm
Awesome! I'd add a loudspeaker and audio link so you can yell at people that get in the way. Shoveling snow from the living room couch is great.
Tommy   10 W
Post by Tommy » Dec 03 2019 8:08pm
veloman, I find myself a little red faced(adding ICE engine). I added all wheel drive this year, but
didn't add more batteries, I'm going to add a 3.5hp ICE engine with electric start that powers a 100amp alternator
to charge the current 200Hr 24vdc battery setup. I got an arduino nano doing an auto start of the ICE engine so it
can be controlled from the remote, single on/off switch.
I tested this setup on my standup mower that has a dc servo motor drive setup on it this mowing season,
and I loved it, no run time limit(sweet!)
fechter, if I did anything like that I'd use an old 1980's dos shareware program called tran (text to speech).
Hillhater   100 GW
Post by Hillhater » Dec 04 2019 7:34pm
I admire your ingenuity , and amused that you have resorted to 1950s ICE tech (Briggs side valve motor) to enable your 2020s device to have extended functionality :bigthumb:
Maybe you can adapt one of these fully electric ,continuous operation, tractors to mowing duties ? :shock:
Tommy   10 W
Post by Tommy » Dec 05 2019 6:39am
Hillhater, if I had john Deere's budget I could replace all my flooded Lead-acid batteries
with lithium polymer batteries, maybe then I wouldn't need the ICE for snow shoveling/plowing, for mowing
I think I would still need an ICE no matter what current battery tech I used.(mow 4 acres each week)
fall 2017 image with 50" snow plow attachment
not once did I think to try corded electric for mowing :shock:
on a side note: if your into FPV the current 4k monitors are very sweet!, got a 43" 4k monitor for under $200usd(sweetest!)
3840x2160 resolution can display a lot of information.(I can now add a few more cameras)
