Sourcing the Damn Parts
Dauntless   100 GW
Post by Dauntless » May 04 2014 11:08pm
Unless I miss my guess there's a spur gear differential in there. Even if it isn't there's a kewl hub.
Sometimes I see things I can use when projects are posted online, but the people never say where they came from.
Is there something I'm missing about finding these parts?
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
Herrsprocket   100 W
Re: Sourcing the Damn Parts
Post by Herrsprocket » May 05 2014 1:01am
Can't even guess who makes the wheel in the second pic. But the first pic looks like a differential that I have seen on the Greenspeed Anura trike or quad. This is a recumbent manufacturer. I can't tell from your pic, but the Anura differential also has a mount on the other side of the disc brake for a gear cassette to mount to it.
Drunkskunk   100 GW
Post by Drunkskunk » May 05 2014 8:40am
To me that looks like a fairly seriously modified gocart differential. Might also be a diff from a small quad. The brake is where the drive gear would normally be, and the sprocket is sandwiched between the halves.
John in CR   100 GW
Post by John in CR » May 05 2014 9:59am
We hoarders of ebike stuff snap things up when we run across it. I've been sitting on a differential a lot like that for 4 years now. :mrgreen:
Dauntless   100 GW
Post by Dauntless » May 05 2014 9:30pm
Oh, I have stuff I haven't been able to use yet. Bigger than just finding those particular parts, I'm wondering at people who can just find what they need. It would be great to just have CATALOGS to look up what I could use.
- Arthur C. Clarke
Herrsprocket   100 W
Post by Herrsprocket » May 08 2014 6:23pm
Ah, this looks more like it. I had it in a favorite website list.
http://www.samagaga.com/Category.aspx?Category=DG72
Tomas
Herrsprocket   100 W
Both made by the same company
Post by Herrsprocket » May 08 2014 8:55pm
All I had to do was poke around a little more on the same site and there she be. The fancy hub/wheel was on the same site as the cool differential. Couldn't find prices though,,,, hmm.
http://www.samagaga.com/Category.aspx?Category=HCWS
Tomas
Dauntless   100 GW
Post by Dauntless » May 08 2014 9:35pm
Oh dang, I'll take that website, thanks!
I do think they want to sell BATCHES, but maybe I can work that out.
- Arthur C. Clarke
Herrsprocket   100 W
Post by Herrsprocket » May 09 2014 2:39am
John, you talk about hoarding stuff. I drew up my first recumbent electric assist trike back in 1984, and bought a Tecumseh riding lawnmower rear differential to use as my drive to the back end. I had that thing "waiting" in the garage for over 20 years before I put it together. It looks just like the Comet go cart differentials that I saw prevalent in the '90's. Works great! I used a 3/4" diameter shaft for that project, and I also bought a 1" diameter axle for some other "project X".
It's funny how on the site it says that the differentials (with the cassette or freewheel mount) that also have a disc brake compatible mount on the housing, says that you're not supposed to use the disc brake on the housing for braking. HUH? Why did they put it on there? It mentions that braking should be done at each rear wheel. Did I miss something? My Tecumseh differential works fine with the disc rotor I had made special to fit the bolt pattern holding the housing together. The rotor brakes the entire housing which stops both output axles from rotating. I don't see why that would not be the same case for the Samagaga differentials. Go figure.
And now I've got some parts that I've only had a year or so (so not really deeply archived) that I'm trying to sell,,, and not much interest in them. Maybe I need to wait 20 years before somebody says, "hey, that would work". It's all good!
Tomas
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » May 09 2014 10:52am
John in CR wrote:We hoarders of ebike stuff snap things up when we run across it. I've been sitting on a differential a lot like that for 4 years now. :mrgreen:
It's that what's happening to my storage space? Damn!
I have enough to put together 4 bikes at the moment :shock:
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Chalo   100 GW
Post by Chalo » May 09 2014 11:55am
Contes Engineering is the only USA distributor I'm familiar with. That's where I'd start asking if I was looking for single vehicle quantities.
My pedicab outfit looked at using these, but settled on the heavier, cruder and more widely available Peerless unit. We had too many questions about the Samagaga diff's ability to withstand a pedicab's high torque, didn't want to commit to using strange diameter axles, and couldn't be sure that those splined parts would remain available to us in the long run.
It's a much more elegant and nicely made diff than Peerless, though.
agniusm   10 MW
Post by agniusm » May 12 2014 12:28am
Ask Jerry at Samagaga. He will sell you what you need. I have posted a while back about their stuff with some pricing, thou it must be a year old: http://www.endless-sphere.com/forums/vi ... ga#p732145
P.S.
On the same note for sourcing the damn parts, i need to source tricycle wheel hubs with disc brake mounts that wont brake the bank. I need to build electric trike, electric only, no chain drive. I have some wheelchair single sided wheels but they don't have any brake mounts. Would appreciate for info
Perhaps someone knows cable operated brakes that are for both sides, left and right caliper?
m4s73r   100 W
Post by m4s73r » May 12 2014 6:52am
Wheels are an upgrade option from Terratrikes. Should be able to order them from the website.
agniusm   10 MW
Post by agniusm » May 12 2014 9:25am
Wheels are Samagaga product as well. You can buy them direct.
