Kingfish
I have several other irons in the fire. When not working on ebike – I am dabbling in other areas. At present a project that has taken over my work space is the R&R of my XBox 360. A week ago last weekend it went belly-up and gave me the E74 Error Code which translates to “a bad AV cable”. What nonsense; the cable has been static for years and years. Sadly my Halo version of the 360 is far beyond warrantee.
Admittedly – I have been having issues with the unit for the past year, maybe two – with the fans never shutting down after I turn the console off. I knew the writing was on the wall - though always thought the power supply brick was the culprit. Until now.
Reading about the E74 Error, it is very similar to the RROD (an equivalent to BSOD for Windows). I could not believe the amount of bogus disinformation on youtube posted by nitwit noobs. I particularly (not) liked the “towel treatment”: Wrap your XBox with a wet towel, fire it up and let it overheat. This changes the Error Code from E74 to RROD – which is even more serious. Then, after cooling for 20-30 minutes, fire it up again – and walla – the mysterious error has self-corrected! In actuality – the unit becomes so hot that it remelts the solder joints -> leading to the clue of what is really wrong with the unit!!
Overheating
We knew this from a long time ago: The XBox was flawed with heating issues. For years I’ve had mine sitting on a tripod of 3-inch tall standoffs to increase airflow and radiation. Taking the plunge and diving into the repair, I got as far as the inner Aluminum case and main PCB before being blocked by Torx T8 screws. <grumbles>. No one had them locally – so I ordered off Amazon a full set of the T8 and below size that was missing from my tool collection, and elected to go the route of using the finest ArctiClean (I & II), plus I have a real chance now to experiment with IC Diamond Thermal Compound! Anyway – all those bits were ordered last week and they have finally arrived today.
[youtube]Bo2dl2vlwis[/youtube]
XBOX 360 Repair Guide - #1
[youtube]mvdJ-Q_T6Js[/youtube]
XBOX 360 Repair Guide - #2
[youtube]I-wni_SNFXU[/youtube]
XBOX 360 Repair Guide - #3
There are a lot of helper videos out there, but for every one, there is 3X more crap-tech solutions. Caveat emptor
Replace the X-spring design with pan heads or not? It really does appear to be Rube Goldberg design: Spring-mounted pressure of the heat sinks against the chips as opposed to firm non-spring contact pressure. You tell me.
Anyways… now that I have the tools – heat sinks were removed. I was sooo grateful that the amount of thermal compound previously applied appeared to be factory-normal, and not burbled over in gobs of waste after some wretched 3rd-party R&R that I have seen in some youtube videos. The ArctiClean-I did a brilliant job of loosening the thermal debris. Some special notes:
For myself, I took the extra step of using Isopropanol to wipe down the surfaces after the ArtiClean (being that I had a LOT more of this solution) to clean up residual residue. From the videos, one could see that once the thermal compound is removed, there is still a trace… like a mask of material indicating the footprint where the original placement was. I had this issue too and resolved to go one step further to eliminate all possible layers of influence by using a little Bon Ami with water and working it with my fingers until the ghost of the footprint was removed.
The next step awaits until tomorrow as I finish the repair. Need to decide to make a run to Ace Hardware for screws and washers to replace the odd spring design, or not.
So listen: I did not use a pair of pliers to remove the studs from the heatsinks, no! A 1/4-inch wrench will do it perfectly. :wink: That took me by surprise as I expected it would take a 7mm wrench. Even in this late global economy American tooling influence still reigns in foreign assembly lines. Go figure
Anyone else have to go through all this on their XBox? Personally, I find the challenge to be a nice distraction from the ordinary, and relish the opportunity to use new thermal compound on a practical domestic device.
Minecraft awaits. KF
Overheating
