The "tail" of the flying kitty
silviasol   10 kW
Post by silviasol » Sep 19 2014 1:48am
I was out riding tonight and while going up one of those spiraling freeway walkway bridges I see some kind of animal's eyes from my headlamp. It starts to head up the spiral bridge so I followed it thinking it was a fox that I had seen in the area before, I get to the top and it must have thought it would make a better escape jumping off the bridge rather then running across the entire ramp so the cat leaps up onto the ledge and jumps off without any regret. Seconds later I hear a large thud, which did sound like it landed on all fours just bottomed out real good. Stood there in shock for a second that it would jump from atleast 30 maybe 40 feet but then looked over and didn't see it keeled over so I guess it was able to run off unharmed. Went back a little later to check out the area from the first level of the spiral just to be sure and pretty sure it made a clean escape. Lol.
Current project: 10s 20ah sensored goped hoverboard
http://endless-sphere.com/forums/viewto ... 35&t=62155
RLT   10 kW
Re: The "tail" of the flying kitty
Post by RLT » Sep 19 2014 2:05am
Glad it was OK.
silviasol   10 kW
Post by silviasol » Sep 19 2014 2:13am
Yea I used to have cats before I moved out of my parents so I felt relieved.
r3volved   100 kW
Post by r3volved » Sep 19 2014 6:42am
Cats have a non-fatal terminal velocity. Counter-intuitively, the higher the fall, the better the chance of survival
melodious   100 kW
Post by melodious » Sep 19 2014 7:33am
8 more lives to go... :lol:
Can't say the same with the bird I saw fly head first into my high rise building the other day. I blame the large amount of clear/reflective windows that reflect the sky's color back. :(
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
Nehmo   10 kW
Post by Nehmo » Sep 19 2014 8:26am
r3volved wrote:Cats have a non-fatal terminal velocity. Counter-intuitively, the higher the fall, the better the chance of survival
Is that true? You mean I cat can jump out of a plane without a parachute?
`~- Nehmo
r3volved   100 kW
Post by r3volved » Sep 19 2014 8:44am
http://en.wikipedia.org/wiki/Cat_righting_reflex
A falling cat's terminal velocity is 100 km/h (60 mph) whereas that of a falling man in a "free fall position" is 210 km/h (130 mph).
With their righting reflex, cats often land uninjured. However, this is not always the case, since cats can still break bones or die from extreme falls. In a 1987 study, published in the Journal of the American Veterinary Medical Association, of 132 cats that were brought into the New York Animal Medical Center after having fallen from buildings, it was found that the injuries per cat increased depending on the height fallen up to seven stories, but decreased above seven stories.[8] The study authors speculated that after falling five stories the cats reached terminal velocity and thereafter relaxed and spread their bodies to increase drag.
Feline high-rise syndrome: 119 cases (1998–2001): http://jfm.sagepub.com/content/6/5/305
silviasol   10 kW
Post by silviasol » Sep 19 2014 8:26pm
Here is the jump!
mrzed   100 W
Post by mrzed » Sep 19 2014 11:30pm
That looks more like 10-12 feet, I'd jump off that onto grass in a pinch.
silviasol   10 kW
Post by silviasol » Sep 20 2014 1:31am
It is a freeway overpass. Looking down is very high, the picture is distorted from googl's 360 camera.
TheBeastie   1 MW
Post by TheBeastie » Sep 20 2014 3:00am
That cat was so passive in the plane but as soon as it saw it was heading out the door it started kicking its legs around like crazy, lol.
I guess a cat couldn't make it out of a plane, but I wonder if a Sugar Glider possum could glide all the way down from 10,000 feet in the air. I guess it would have to be a test for Mythbusters evil deeds edition.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
silviasol   10 kW
Post by silviasol » Sep 22 2014 5:32am
Speed Kills Range, 10mph = 46 miles range, 15mph = 30 miles range, 20mph = 20 miles range, 25mph = 13 miles range, 30mph = 8 miles range http://bit.ly/1avtI5Y
True, true. I went from 9/76 to 13/76 gear ratio on my scooter and could not believe the range drop! Love the speed though.
