hjns
Hi all,
It has been a long time since I posted here. But I have something new planned. First some background.
After a couple of years of experimenting with different kinds of DIY ebikes, I decided to buy a Haibike. But this is only the beginning! Read more below the picture...
As you can see, the Haibike has a Bosch mid-motor, estimated at around 350W. Max speed is around 42kmh (electronically limited) and peak power is probably something around 800W through the gears. With this, I can get up a 30% incline without any issues, but only in lowest gear.
However, recently, I saw the All-Axle Hub motor from Justin for beta testing. See below, the picture that was taken from the Ebikes.ca website.
OK, the plan is to combine both. The Justin's motor has been ordered. After testing with a Phase Runner, CA3 and CA logger, I will lace it into a 650B DT Swiss rim and assemble into my Haibike. I will report on the progress here. Hope you guys may find it entertaining...
