Cookware must be compatible with induction heating; in most models, only ferrous metal can be heated. Cookware usually have a flat bottom since the magnetic field drops rapidly with distance from the surface. (Special and costly wok-shaped tops are available for use with round-bottom woks.) Induction disks are metal plates that are heated by induction and heat non-ferrous pots by thermal contact, but these are much less efficient than ferrous cooking vessels.
Induction compatible cookware for an induction cooking surface can nearly always be used on other stoves. Some cookware or packaging is marked with symbols to indicate compatibility with induction, gas, or electric heat. Induction cooking surfaces work well with any pans with a high ferrous metal content at the base. Cast iron pans and any black metal or iron pans will work on an induction cooking surface. Stainless steel pans will work on an induction cooking surface if the base of the pan is a magnetic grade of stainless steel. If a magnet sticks well to the sole of the pan, it will work on an induction cooking surface. An "all-metal" cooker will work with non-ferrous cookware, but available models are limited.
Aluminum or copper alone does not work on an induction stove because of the materials’ magnetic and electrical properties.[21] Aluminum and copper cookware are more conductive than steel, but the skin depth in these materials is larger since they are non-magnetic. The current flows in a thicker layer in the metal, encounters less resistance and so produces less heat. The induction cooker will not work efficiently with such pots. However, aluminium and copper are desirable in cookware, since they conduct heat better. Because of this 'tri-ply' pans often have an induction-compatible skin of stainless steel containing a layer of thermally conductive aluminum.
For frying, a pan with a base that is a good heat conductor is needed to spread the heat quickly and evenly. The sole of the pan will be either a steel plate pressed into the aluminum, or a layer of stainless steel over the aluminum. The high thermal conductivity of aluminum pans makes the temperature more uniform across the pan. Stainless frying pans with an aluminum base will not have the same temperature at their sides as an aluminum sided pan will have. Cast iron frying pans work well with induction cooking surfaces but the material is not as good a thermal conductor as aluminum.
When boiling water, the circulating water spreads the heat and prevents hot spots. For products such as sauces, it is important that at least the base of the pan incorporates a good heat conducting material to spread the heat evenly. For delicate products such as thick sauces, a pan with aluminum throughout is better, since the heat flows up the sides through the aluminum, allowing the cook to heat the sauce rapidly but evenly.
Aluminum foil in a square Pyrex dish of water, with a tear where the foil has melted
Household foil is much thinner than the skin depth in aluminum at the frequencies used by an induction cooker. Here the foil has melted where it was exposed to the air after steam formed under it. Cooking surface manufacturers prohibit the use of aluminum foil in contact with an induction cooking surface.
The heat that can be produced in a pot is a function of the surface resistance. A higher surface resistance produces more heat for similar currents. This is a “figure of merit” that can be used to rank the suitability of a material for induction heating. The surface resistance in a thick metal conductor is proportional to the resistivity divided by the skin depth. Where the thickness is less than the skin depth, the actual thickness can be used to calculate surface resistance.[21] Some common materials are listed in this table.
Skin depth at 24 kHz[21] Material Resistivity
(10−6 ohm-inches) Relative
permeability Skin depth,
inches (mm) Surface resistance,
10−3 ohms/square
(thick material) Surface resistance,
relative to copper
Carbon steel 1010 9 200 0.004 (0.10) 2.25 56.25
Stainless steel 432 24.5 200 0.007 (0.18) 3.5 87.5
Stainless steel 304 29 1 0.112 (2.8) 0.26 6.5
Aluminum 1.12 1 0.022 (0.56) 0.051 1.28
Copper 0.68 1 0.017 (0.43) 0.04 1
TABLE GOT ALL BUNGLED UP WITH COPY AND PASTE. SORRY ABOUT THAT.
To get the same surface resistance as with carbon steel would require the metal to be thinner than is practical for a cooking vessel; at 24 kHz a copper vessel bottom would need to be 1/56th the skin depth of carbon steel. Since the skin depth is inversely proportional to the square root of the frequency, this suggests that much higher frequencies (say, several megahertz) would be required to obtain equivalent heating in a copper pot as in an iron pot at 24 kHz. Such high frequencies are not feasible with inexpensive power semiconductors; in 1973 the silicon-controlled rectifiers used were limited to no more than 40 kHz.[21] Even a thin layer of copper on the bottom of a steel cooking vessel will shield the steel from the magnetic field and make it unusable for an induction top.[21] Some additional heat is created by hysteresis losses in the pot due to its ferromagnetic nature, but this creates less than ten percent of the total heat generated.[22]
