Varabou said:
kV is 9.03 x 72V so my max rpm is 650 at load and also unloaded?
Kv is the voltage constant of the motor, which means with the pack voltage at 72, the bare motor without any load (even the air resistance a tire) in the air will spin at 650rpm at 100% throttle. As load increases, rpm at full throttle decreases, and current increases with the increased torque demand of higher loads.
Kv is inversely related to a motor's Kt, torque constant, the amount of torque it makes per amp supplied. 9.55/Kv = Kt in Nm, so that motor will produce just over 1 newton-meter of torque per amp applied, or 0.78 foot-pounds per amp.
Our hubmotors are limited by their ability to shed heat, and in their designed rpm range a hubmotor's heat comes primarily from heat losses in the copper due to resistance. That means they are happiest at high rpm, since current is lower and heat in the copper goes up with the square of resistance. I'd make my design flexible so that if I ran into heat problems I could solve it with the bottom part of the motor in a water bath.
You should message Bzhwindtalker, who has built a wake-winch using a hubmotor, though he used a less capable motor than the one you mentioned.
Since your gearing is variable, if you haven't already purchased your motor, I would suggest choosing one with a higher Kv. That's because their lower copper resistance means they can run at higher power for a given voltage.
