nutnspecial
I have installed a few small forced air-furnaces and am fairly aware of the common problems/maintanence, but my current issue is totally new.
5yo furnace, and it kinda vibrates from the blower motor /squirrel cage. I pulled the assembly out and it's clean and fairly straight/balanced.
I guess it's an ecm motor- it looks like there's one neutral and a few (4) hot (+) wires for various speeds or whatever. Then there's two for the capacitor.
When I then energized it, a shudder or miss/skip became very evident as it winds up and seems to be the issue of the shudder at full rpm, transmitting thru the furnace.
I don't see any brushes, but it almost seems like if it's only 'running on one cylinder', like if one brush was screwed up etc. I didn't think it would be the capacitor but maybe it is?
I did google some stuff most 'vibrations' etc seem to be caused by dirt or messed up / imbalanced squirrel cages, which this def doesn't seem to be.
Just wondering if anyone knows anything about this type of motor that could help. Thanks for reading!
