X-treme XB-600 scooter hub motor
polecat
Looks like my X-treme XB-600 hub motor may have finally died. I'm not getting continuity between the green phase wire and the other two phase wires. Though, I haven't opened up the motor yet, the break is either in the green phase wire leading to the motor windings, or the motor windings themselves. If it turns out to be the windings, anyone have a replacement motor suggestion (compatible with the X-treme XB-600 frame)?
Is this the famous scooter that the John_in_CR Hubmonster came from?
I would say the new MXUS 5K motor, or the high powered QS motors would be more then sufficient.
Thanks Markz,
This is the e-scooter from V is for Voltage (motor rewiring). I noticed Alliexpress sells motor stators. Would a new stator (one that fits the XB-600 hub) be an option?
