Hello everyone, two weeks ago, I had a crazy idea to build a propulsion system for my kayak using a custom made electric waterjet system. I'm a mechanical engineer so I started from the base for everything related to the electricity. In fact, a week ago, I didn't knew that it's was possible to build a battery pack from 18650 cells.
I therefore read a lot on the subject and I just wanted to use your knowledge to be sure I understood everything right. Here's my plan for the electric system:
Motor: 130KV, 7000W, 200A Max Amp, 18S max volt (64.8V)
http://alienpowersystem.com/shop/brushless-motors/c80100-sensored-outrunner-brushless-motor-130kv-7000w/
Custom Battery Pack: 308 cells 18650, 10A 2.6Ah, 14S22P for a total of 58.8V and 57.2Ah
If I understood the math, 10A/2.6Ah = 3.84C and 57.2Ah x 3.84C = 220A so I should be good if Amp battery > Amp Max Motor
ESC: Anything above 220A, like 250A or 300A.
Did I said any stupidity?
Thanks for your help!
