AC clamp current sensor on DC?
rg12   100 kW
Post by rg12 » Dec 03 2017 8:09am
Hey Guys,
Can I use an AC amp meter monitor designed with an AC clamp sensor on DC current?
Manny   10 W
Re: AC clamp current sensor on DC?
Post by Manny » Dec 03 2017 8:43am
depends on the sensor tech.
if it uses a current transformer no you can't use it on dc
if it uses a hall effect sensor, it might work
dustNbone   10 kW
Post by dustNbone » Dec 04 2017 6:17am
If it doesn't have a specific DC current setting, it's most likely a CT type and won't measure DC. I have a clamp meter that measures DC but it's a specific setting on the dial, and that meter cost about 3x as much as the "regular" clamp meter.
rg12   100 kW
Post by rg12 » Dec 04 2017 11:05am
I'm looking at the ones used in solar systems (those 60V 100A ones) and not at the clamp meter tools.
They have a little blue plastic square that closes on the positive wire.
Do you know of any place that sells 20mm front hub for dual discs?
