sending a private message
Kenny'sID
I just sent a private message and it shows as in my Outbox, not in the Inbox, but no option that I see to send it, and no mention if there is a lag/if it will go out automatically or what? Kind of confusing.
Do I just wait and it will send or do I have to do something manually to make that happen? Thanks :)
https://endless-sphere.com/forums/viewtopic.php?f=13&t=15521&hilit=Outbox
https://endless-sphere.com/forums/search.php?keywords=Outbox&terms=all&author=&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
When you send something, it sits in your outbox, not your inbox, because it's going out. They collect there so you can see everything you ever sent out. That also means it's been sent, but not necessarily read, or else it would be in the drafts.
I'm sorry Voltron but your answer is not only wrong but confusing. AW already answered the question by sending the op to where it was answered over a decade ago.
I'm only jumping in here because some will just read the last post and go away thinking they know what happens even if the post is wrong.
When you "send" a pm to someone it goes to your outbox and stays there until that person reads it, at which time it goes to your sent messages.
Well, they don't actually have to read it, so I probably should have said "until they open it".
It is possible for you to edit the message, or even delete it while it is in the outbox.
