JamieWlcox
- Joined
- Mar 5, 2018
- Messages
- 24
It seems I am having a throttle problem today I went to go for a ride and noticed it at been raining as soon as I got on my bike I turn the power on the throttle and I believe the bike immediately wanted to take off without twisting the throttle so I powered it off and pulled the brake got the wheel to stop spinning I then turn the power back on and had more throttle sticking issues. Today the throttle stuck stopped pause stuck wide open about 5 or 6 times I made sure the bike was parked in a covered area all day coming home from work it seem like the problem had went away this throttle is brand-new only a couple weeks old I think this is the second time it has done this. I'm pretty sure it was raining the first time that's happened as well. How common are these throttle shorts or throttle sticking with these e-bikes I have a durable thin sheet of rubber laying over my throttle that stays in place to prevent water seeping into it evidently it was not doing its job but what I noticed today is sometimes when I went to activate the throttle it would not engage the motor until I spun the wheel a quarter-turn kind of like a Pas system. The controller is pedal assist compatible but not hooked up. I have not noticed this quarter turn Behavior out of the tire necessary for motor engagement until today . Would it be more likely I had water in my throttle or would it be more likely that I had water in my PAs connector or is this just a guessing game and possibly the controller as well. Will this rain shorted throttle cause the controller to fry. I bought one of those e-bike LCD controller system testers on eBay but have not received it yet. My guess is if I can reproduce the throttle sticking and unplug the throttle from the controller this will confirm controller good or bad. I have a a garbage bag over the electronics but this seems a little ridiculous. If this is so common how are there not lawsuits and accidents involved with these malfunctions
