BBSHD and Sturmey Archer S2K 2 Speed Kick Shift Disc Brake Rear Hub
Bullfrog   10 W
Post by Bullfrog » Apr 15 2018 11:03am
Does anybody have experience with the Sturmey Archer S2K 2 Speed Kick Shift Disc Brake Rear Hub?
Or more precisely, has anybody tried it with a BBSHD?
Any words of wisdom, advice, experiences, etc....would be greatly appreciated. I am considering doing a build with a BBSHD, a Bikes Direct bike with horizontal rear dropouts, and the SA 2 speed kick shift rear hub. About as clean as a bike can get because it won't have any shifter cables, a derailleur, or a chain tensioner.
Does anybody know of an inexpensive, steel framed donor bike that has horizontal dropouts? Tentative plan is to use a Deadeye Monster from bikesdirect.com (aluminum frame) but I prefer steel, just don't want to drop the money required to buy a Surly :D .
Thanks for any info...positive and/or negative comments and advice are appreciated.
cal3thousand   1.21 GW
1.21 GW
Re: BBSHD and Sturmey Archer S2K 2 Speed Kick Shift Disc Brake Rear Hub
Post by cal3thousand » Apr 20 2018 2:35pm
I've never had one, but reading about it a bit, I have questions on how you expect it to work with a BBSHD. So if you want to shift, you will get off throttle and hit reverse? I don't understand how you will get the chain to travel backwards to initiate the shift, since the BBSHD has an internal freewheel at the crank.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
