izeman
1 GW
i got a little vacuum cleaner. originally powered by 6s 1500mAh NICD batteries.
they got weak after 10 years, and i replaced them by 2s2p 30q samsung 18650 cells.
i also installed a 2s 13A BMS. this was the strongest one i could find on aliexpress. it has a shutdown current of 20A.
and this little motor really draws A LOT OF AMPS on start. my current meter showed 20A plus, and 13A during constant use.
the BMS shuts down when the motor starts to turn. how could i reduce the inrush current automatically? is there a way to do it easily?
thanks!
thanks!
