How do I run headlight off battery?
kcaravelli2   1 µW
Post by kcaravelli2 » May 15 2018 8:20pm
I'm having a new BBS02 installed on an HPV Scorpion FS 20" recumbent trike this week by Rose City Recumbents.
They have been able to get me a great battery from Luna Cycle:
48v Panasonic GA 17.5ah Black Killer Whale:
https://lunacycle.com/48v-panasonic-ga- ... uge-range/
This battery has a USB port as well as both charge ports and main port for the motor.
** I think the connectors are xt60 and xt90 plugs.
Question:
What do you recommend for a lighting setup to run directly off the battery?
What light and how would I setup a light to run directly off the battery.
For example, there are Battery dual adapter cable connectors for output to another source like a light and not just a dual battery output.
Any thoughts on how to do this?
Thanks,
Keith
Olympia, WA
tomjasz   1.21 GW
1.21 GW
Re: How do I run headlight off battery?
Post by tomjasz » May 17 2018 2:26pm
Easiest way, use a 48V rated light set.
Simply google 48V bicycle light
markz   100 GW
Post by markz » May 17 2018 3:02pm
DC to DC converter
Buck Converter
ebay
spinningmagnets   100 GW
Post by spinningmagnets » May 17 2018 6:35pm
Search Ebay for DC/DC 48V golf cart. They use 12V car lights and radios...find one that specs a 60V input max, the capacitors are 63V, so they will take 12S/13S/14S input...
dingoEsride   100 kW
Post by dingoEsride » May 17 2018 8:48pm
I use this type, direct to the battery up to 80v, 20w is very bright but 8w should do or have a couple with switching between.
https://www.ebay.com.au/itm/12V-80V-20W ... 238002bf74
ride like the wind
flippy   10 kW
Post by flippy » May 25 2018 1:44am
dingoEsride wrote:
May 17 2018 8:48pm
oncoming traffic must love you.
Lithium beats liquid dinosaurs.
dogman dan   100 GW
Post by dogman dan » May 25 2018 5:38am
FWIW, any led light that runs on three dry cells or one lithium cell (4.5v) should run off that USB port. That opens up lots of choices. I'm not sure what voltage the typical bike lights use now. Things tend to change faster than I can keep up.
I can say this though, the five dollar version of 48v bike headlight is junk. It was just dim, had a shitty reflector and lens so it did not throw a beam. So dim as it was it would blind the guy you really want to see you. Of course he does see your light, but then drives off blinded to anything else, dogs, pedestrians, etc.
That ebay link looks like a good solution. Looks like 4 just like the light I thought too dim. It could have a brow added to keep the light down on the road more, and off the drivers windshields.
Since I run at night fairly seldom, my best solution ended up just a rubber handlebar mount that holds a typical very bright led flashlight.
On the other hand, a 48v to 12v converter on the bike does open up a big world of 12v stuff you can run off it.
DrkAngel   100 GW
Post by DrkAngel » May 25 2018 9:33pm
Index - Homemade Battery Packs - Updated - February 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
lionman   100 W
Post by lionman » Jun 14 2018 11:18pm
Does anyone know if you can run a light that says its compatible with 48v with a 52v battery pack?
flippy   10 kW
Post by flippy » Jun 15 2018 12:35am
fully charged 48v battery is 58V
lionman   100 W
Post by lionman » Jun 16 2018 3:58am
flippy wrote:
Jun 15 2018 12:35am
Yep, I know that. That doesn't answer the question though.
flippy   10 kW
Post by flippy » Jun 16 2018 7:49am
48V implies lead acid. So they would take that into account. Usually they have 60v electonics inside. It has to be really shitty stuff if it blows up at 57V
trappermike   100 W
Post by trappermike » Jun 17 2018 7:43pm
A few years ago I purchased from China some really nice DC-DC converters(to 12v) for 48v systems and some for 72v systems rated for 10 amp output. They came in a nice finned aluminum case and had a fuse included,nicest units I've ever seen. Price was about $6 each,no failures...
Then find a good 12v LED light and run other 12v accessories too.
