NEED HELP! New ebike build questions
tbraysfan11   1 µW
Post by tbraysfan11 » Jul 08 2018 10:42pm
So I really need some help and information. I just built my first ebike last weekend. I bought an ebikeling 1500w rear hub kit. Paired it with a luna cycle 48v 24ah Panasonic battery. Controller is supposed to be 35 amp. My questions are, why does the sw900 display only let me go between 1 and 20 amps and even set at 20 amps when at full throttle even from dead stop the most watts the sw900 says is like 700 watts. Why isn't it getting close to 1500watts? Another question is if the problem is the controller, if i replaced it is my motor compatible with an em3ev controller and would it even make a difference. With my current set up i can get to 30mph but not much torque at all. Im 200 lbs btw
tbraysfan11   1 µW
Re: NEED HELP! New ebike build questions
Post by tbraysfan11 » Jul 11 2018 12:30pm
Can anyone please help me out
docw009   10 kW
Post by docw009 » Jul 11 2018 10:53pm
Have you asked using the contact email on ebikeling's website? HE has gotten back to me on my SW900 queries, although the answer didn't help. I don't feel the SW900 is a very good control unit. I junked mine along with the controller.
By the way, isn't the watt display only 3 digits? How would it go over 999?
tbraysfan11   1 µW
Post by tbraysfan11 » Jul 15 2018 3:35pm
Yes your correct its only 3 digits but still should show more watt usage than 700. Tried to talk to ebikeling but the guy doesnt know his ass from a hole in the ground. He couldnt even tell me any specs on his own controllers hes selling
ScooterMan101   1 MW
Post by ScooterMan101 » Jul 16 2018 3:32pm
Em3ev , from what I see on the website only sells Geared Hub Motors
However
A ( Senseless ) Controller from them should work.
Grin Technologies ... http://www.ebikes.ca/ , sells both geared and DD hub motors , which is what yours looks like. They have the expertise to make most everything work. ( They are Electrical and Mechanical Engineer's )
Both Companies are very well recommended , by many people here on E.S. myself Included .
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
HomeScape   10 mW
Post by HomeScape » Jul 16 2018 4:01pm
I might be a little late to the party but i would like to add that your motor isn't the issue here. A 1500w motor might aswell be a 1000 or a 2000W motor. You can technicly pump any current trough any motor. The smaller ones just heat up quick and burn down.
I'd suggest a controller without display, those are the simplest to setup and they don't require a special display to match that specific controller. Most controllers need a specific display to work, if the display would die due to water damage you're down 25+ bucks.
I'm currently messing with some higher tier stuff which is a 5000w hub motor and a 150 amp sabvoton controller. These 'just work' on the basics and for the more advanced things it's a bit of messing around to get going.
thundercamel   1 W
1 W
Post by thundercamel » Oct 03 2018 11:17am
I have an ebikeling 1500w rear hub kit. My sw900 display never even says 1000 watts, but my bluetooth smart BMS says 1500+ watts. My 35mph top speed (on a 14s 52v battery) also points towards it being a genuine 1500 watts.
My Ebike builds - Existing bikes, affordable motor kits, self built 14s6p batteries
