I broke the axle which resembles a threaded rod about half an inch in diameter.
I called Motorino in Vancouver and they said I cannot fix and that I will need the whole unit including the hub, motor, wheel.
I wonder if I can somehow weld this piece or drill it out and put in a new threaded rod on the broken side.
Unfortunately, this is also where the electric cord goes in to power the hub, so it's drilled out.
Any help is appreciated. I am new to this kind of forum.
Thanks,
Chaz
Thanks,
Chaz
